Video over a still
Jul 26, 2012 1:45 PM
Hello,
I have a video in a flash as2 project using cs4.  I have a video that plays with an alpha channel that fades.  I want to have a background still under so when it fades it fades to the still that I have text on.  This is in a flash game I have made.  The problem is when the game goes from question to question it should play the video then fade to the video beneath, but it plays the background for 1/2 second or so, then plays the video which then fades to the background.  Is there a way that the background can be under the video but not show initially?
Thanks for your help.
Mark.
  • kglad
    Jul 21, 2002
    Jul 26, 2012 1:50 PM   in reply to MARKARKARK
    convert your background to a movieclip and assign its _visible property to false until your video starts.
  • kglad
    Jul 21, 2002
    Jul 26, 2012 4:37 PM   in reply to MARKARKARK
    click on your background (to select it) and (in the properties panel) assign an instance name (eg, bg_mc).  do the same with your flvplayback component (eg, flvpb_mc).
    then attaced to the timeline where you want your background to be not visible, use:
    bg_mc._visible=false;
    var lo:Object = {};
    lo.ready = function(eObj:Object):Void {
        bg_mc._visible = true;
    flvpb_mc.addEventListener("ready", lo);
  • kglad
    Jul 21, 2002
    Jul 26, 2012 11:20 PM   in reply to MARKARKARK
    that code should be on the timeline that contains bg1 and q1.
  • kglad
    Jul 21, 2002
    Jul 27, 2012 4:18 PM   in reply to MARKARKARK
    copy and paste the output from:
    trace(bg1);
    trace(q1);
  • kglad
    Jul 21, 2002
    Jul 28, 2012 9:16 AM   in reply to MARKARKARK
    use:
    trace(bg1);
    trace(q1);
    bg1._visible=false;
    var lo:Object = {};
        bg1._visible = true;
    q1.addEventListener("ready", lo);
  • kglad
    Jul 21, 2002
    Jul 28, 2012 12:25 PM   in reply to MARKARKARK
    you're welcome.
    p.s. please mark helpful/correct responses, if there are any.
