"Load files into Photoshop layers" fails to complete CS6
Jul 27, 2012 2:55 AM
Tags: #photoshop #raw #bridge #mac #layers #cs6 #cr2 #load_files_into_photoshop_layers
Hi all,
Hoping someone can help with the folling problem with Photoshop & Bridge CS6
When in Bridge, after selecting 6 images (CR2) using the command TOOLS>LOAD FILES INTO PHOTOSHOP LAYERS the first file will load into Photoshop, Photoshop will then generate a second blank layer and then read the second file. At this point the "script" will stop. I am left with a document with 2 layers. The top layer has my first image, the bottom layer is empty.
At this point when I quit Photoshop I am prompted to save this open document which appears to be the only open document. I choose not to save this as a file. I then get a dialogue box prompting to save another open document. Photoshop has loaded the second file to place as a layer but as the "script" has aborted I am left with an open, but invisible file.
When I first loaded CS6 on Snow Leopard, it would demonstrate this behaviour every time I attempted to run this command from Bridge.
I did a clean install on a blank HDD of OSX Lion. Installed CS6. The command worked without fail for about a month.
Then I would get the command aborting occasionally. Restarting Photoshop would let me continue for a few hours before this aborted script problem would happen again.
Over the last week it has become more frequent, to a point where this workflow is unusable.
A restart of Photoshop may fix the problem for the next batch of images, only to fail again soon after, or fail on the first attempt after a relaunch of Photoshop.
A reboot of my computer will allow my to load one or two sets of files before again failing to complete the command.
I have tried the following:
In Photoshop preferences:
disabling the "Use graphics Processor"
Increasing or decreasing the amount of RAM available to Photoshop
Changing the cache levels or changing the cache tile size
changing the scratch disk
Trashing the Photoshop preferences file (Photoshop Settings.psp)
In Bridge
Purging the cache
Increasing or decreasing the cache size
Resetting Bridge preferences (holding Command on launch) and deleting all cache files.
In general system
Quitting extra programs (Safari, Thunderbird, iTunes)
Sometimes this will seem to then allow Photoshop to load a full set of images, only to abort again after a few sets.
Rebooting the computer - again will work for a few images sets before again failing.
Now the fact that it worked fine for several weeks without presenting a problem would indicate that it is not a bug.
The fact that is slowly started happening then became more frequent would indicate something changing slowly over time - a larger cache folder perhaps, although purging known Bridge cache folders has not filed the problem.
Really at the end of my tether here. Even considering downgrading to CS5 - but don't want to have to use the older Adobe Camera Raw.
System is as follows:
Mac Pro 2 x 2.66 Quad Core
24GB RAM
ATI Radeon HD 4870 512
OSX Lion 10.7.4
I have seen a couple of others have posted having a the same problem, both with CS5 and CS6.
Hoping someone has an answer.
Thanks.
  • Noel Carboni
    Dec 23, 2006
    Jul 27, 2012 3:09 AM   in reply to Geoff8888
    Hi Geoff,
    Any chance you have a shortage of scratch disk space?
    Can't say I've seen the Load Files Into Stack script stop for me, though I've only used it a handful of times.
    There's a log file the Adobe people sometimes ask folks to look in, but I'll be darned if I remember the name or where to find it at the moment.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jul 27, 2012 3:13 AM   in reply to Noel Carboni
    Aha, found a reference to the error log file I mentioned:
    Chris Cox wrote (elsewhere):
    It would be in your Photoshop preferences folder (~/Library/Preferences/Adobe Photoshop CS6 Settings/PSErrorLog.txt).
    That file is created or appended to whenever you hit a program error.
    -Noel
  • JJMack
    Jan 9, 2006
    Jul 27, 2012 4:11 AM   in reply to Geoff8888
    If you have un-checked "Open Documents in Tabs" in your CS6 Photoshop Preferences use menu Edit>Preferences>Interface then check  "Open Documents in Tabs"  I know on a Windows System this will get around a bug in CS6 that caused "Load Files it to Stackj" to fail. If that bug is also in the Mac version  it may be what is causing your Mac Bridge " TOOLS>LOAD FILES INTO PHOTOSHOP LAYERS" to fail. What seem to be happeng is that one document is closed and Photoshop switch beack to the previous active document but before the document actually becomes active he next script command starts to executes and if the commend requires an active docuent it fails. When run from Photoshop you get a message like command not currently available or in may not be supported in this version of Photoshop.  On a PC many Actions and Scripts will fail if  "Open Documents in Tabs" is un-checked
    Nov 30, 2012 4:01 PM   in reply to Geoff8888
    Using iMac with 12 GB RAM.  I have had this same issue for over a year.  I complained last year and a technician went through many of the suggestions here, to no avail.  Thinking it might be a memory (my RAM) issue, I just upgraded my RAM - they found one bad unit but problem still persists.  The two really nagging things about this:
    1.  It seems to be totally random.  Sometimes the images load (up to 8 separate images in separate layers; as few as 3 cause the problem), sometimes not.  No repeatable practice can generate the problem nor fix it.
    2.  Adobe seems absolutely mute about admitting there is a problem or fixing it.  Obviously if others are having the problem it is an Adobe PS problem
    Please fix it!!!
    fmrhoades@comcast.net
  • Noel Carboni
    Dec 23, 2006
    Nov 30, 2012 5:49 PM   in reply to FMRhoades
    I was hoping someone from Adobe might comment on the errors Geoff listed in that PSErrorLog.txt file.
    This is the sum total of what's in my PSErrorLog.txt file:
    2012:10:26 12:08:10 : ..\..\sources\ZStrings.cpp : 5342 : REQUIRE failed
    For those of you still having trouble with this, are you on 13.0.1?
    -Noel
    Nov 30, 2012 6:31 PM   in reply to FMRhoades
    After making this post and reading some of the other posts in this discussion, I thought perhaps there was another way to accomplish layer loading.  I can't pretend to be a PS expert - there is just too much to fathom in this program.  However I did a little searching and came up with the following work around.
    Start PS (forget about Bridge). Choose Files - Scripts - Load Files into Stacks.  This brings you to a file browsing window where you can choose the files to load into layers.  This seems to do exactly the same thing as using Bridge - Tools - Photoshop - Load files into layers (although for some reason Adobe chooses completely different language and completely different locations to do the same thing).
    The PS script has worked for me every time so far.  Perhaps I just am lucky but, if this script works, and the Bridge script doesn't, then the problem is in the Bridge script.  Could someone fix it?
    Fred Rhoades
    Dec 5, 2012 11:42 AM   in reply to FMRhoades
    Disregard the 11/30 post
    Continued trial of the "in Photoshop script" approach suggests that it behaves exactly like the problem using the Bridge>Tools>Load into Photoshop Layers approach.  That is, the problem is random, occurs and then does not occur, does not depend on the number of files attempted:  will occur with as few as 2, doesn't occur with as many as 8 images (of the 22 megabyte size).  This is a vexing problem, particularly because it is not reproduceable with any set sequence of operations
    Dec 5, 2012 12:13 PM   in reply to JJMack
    Halleluja -- this adjustment:  Uncheck "Open Documents in Tabs" in your CS6 Photoshop Preferences using menu Edit>Preferences>Interface then uncheck  "Open Documents in Tabs" solves the problem I and others reported.  Sorry I did not closely read all the posts in this thread before.  PLEASE Adobe, when a problem like this is reported on, and others suggest a solution.  THIS MEANS THERE IS A BUG THAT NEEDS TO BE FIXED.  Please put it on your list.
    Dec 18, 2012 7:05 AM   in reply to Geoff8888
    I just encountered the same exact problem as the OP.
    FWIW, I quit PS & Bridge - then relaunched PS then Bridge and attemted the same from Bridge and it worked.
    Before I first tried to do it in PS via Mini Bridge and had the same problem... Thinking that was the problem.
