Image post in Facebook wall
Jul 27, 2012 12:41 AM
       I would like to know, how can i post the image in facebook and google+ via my flash interface developed in AS2. Any ideas will be pretty much helpful for my developement as i don't have any idea of doing it.
I have created the site and user can upload the files from his desktop. my pendig part is, if user wants to post a image from his uploaded photo, he needs to have a option for that.
Kindly help me out.
Regards,
Kameshwaran A.
  • kglad
    Jul 21, 2002
    Jul 27, 2012 7:14 AM   in reply to A.kameshwaran
    after logging in the user, you can use (with the externalinterface class in flash to call feedF and receive the return from fb by defining swfF) the following javascript:
    function feedF(){
        var obj = {
          method: 'feed',
          link: 'http://www.kglad.com/Files/fb',
          picture: 'http://www.kglad.com/Files/fb/game_01.jpg',
          name: 'game_01 feed test',
          caption: 'game_01',
          description: 'game_01 feed dialog.'
        FB.ui(obj, function(response){
            toSWF("feed response **");
            evalF(response);
    function evalF(obj){
        if(typeof obj == "object"){
            for(var s in obj){
                toSWF(s);
                evalF(obj[s]);
        }  else {
            toSWF(obj);
         function thisMovie(movieName) {
             if (navigator.appName.indexOf("Microsoft") != -1) {
                 return window[movieName];
             } else {
                 return document[movieName];
         function toSWF(value) {
             thisMovie("game_01").swfF(value);  // use your swf's name
  • kglad
    Jul 21, 2002
    Jul 27, 2012 11:16 PM   in reply to A.kameshwaran
    just pass whatever arguments you want to use:
    function feedF(linkS,imageS);
    ar obj = {
    method: 'feed',
    link: linkS,
    picture: imageS,
    caption: 'game_01',
  • kglad
    Jul 21, 2002
    Aug 1, 2012 12:20 AM   in reply to A.kameshwaran
    you're sending a variable to feedF but feedF does not accept a parameter.  fix that.
  • kglad
    Jul 21, 2002
    Aug 1, 2012 7:32 AM   in reply to A.kameshwaran
    did you login the user and get permission to post to their wall?
  • kglad
    Jul 21, 2002
    Aug 3, 2012 7:06 AM   in reply to A.kameshwaran
    you should use something like the following to login the user:
      (function(d, s, id) {
            var js, fjs = d.getElementsByTagName(s)[0];
            if (d.getElementById(id)) return;
            js = d.createElement(s); js.id = id;
            js.src = "//connect.facebook.net/en_US/all.js#xfbml=1&appId=229095550543776";
            fjs.parentNode.insertBefore(js, fjs);
        }(document, 'script', 'facebook-jssdk'));
        // initialize with fb js (after it loads) with your App ID
        window.fbAsyncInit = function() {
          FB.init({
            appId      : 'YOUR APP ID',
            status     : true, // check login status
            cookie     : true, // enable cookies to allow the server to access the session
            xfbml      : true  // parse XFBML
          // fbLoginStatus is called when there is a login status change and when fb js initializes
          function fbLoginStatus(response) {
              // If the user is logged in, response.status is 'connected'
              if (response.status === 'connected') {
                FB.api('/me', function(response) {
                    toSWF("is connected:: "+response.status);
                    evalF(response);
              } else {
                  // The user is not logged-in.
                  toSWF("not connected:: "+response.status);
                  evalF(response);
          // This is the code that calls fbLoginStatus on initialization
          FB.getLoginStatus(fbLoginStatus);
          // This is the code that call fbLoginStatus when there is a status change
          FB.Event.subscribe('auth.statusChange', fbLoginStatus);
    // and you can use the following to request permissions.  the permissions are hard-coded below but you may want to pass a parameter to permissionsF if you want flexibility here:
    function permissionsF(){
        var obj = {
            method: 'permissions.request',
            perms: 'user_birthday,user_relationship_details,read_stream',
            display: 'popup'
        FB.ui(obj, function(response) {
             toSWF("permissions **");
             evalF(response);
    p.s.  please mark helpful/correct responses.
