DVF2
Converting PDF to PNG
Jul 27, 2012 6:20 AM
Tags: #illustrator_cs5 #applescrit #current_document
I wrote the following AppleScript to open a PDF file and export is as PNG.
I am using Illustrator CS5.
The export command gets an error: Adobe Illustrator got an error: Can't get current document.
when it encounters the export command.
What is causing this and how do I fix it?
set inputFile to (choose file with prompt "Open PDF file to convert to PNG:") as text
set exportFile to inputFile & ".png"
tell application "Adobe Illustrator"
    if not frontmost then activate
    open inputFile as alias without dialogs
    export current document to exportFile as PNG24 ¬
        with options {class:PNG24 export options ¬
        , resolution:300 ¬
        , matte color:{red:0, green:0, blue:0}}
    close current document saving no
end tell
    Jul 28, 2012 4:27 AM   in reply to DVF2
    I tried your script and while the error kick back say's its a file/document issue… It's NOT you have supplied a bad parameter… resolution NO such thing except for PSD… Remove and you will be fine…
    Jul 28, 2012 7:06 PM   in reply to DVF2
    You will have to scale the PNG larger and then batch reduce in Photoshop to get the resolution you want. AI thinks all PNGs are 72 ppi.
    Jul 30, 2012 9:46 AM   in reply to DVF2
    Set the transparency to false and the matte color to 255, 255, 255
