CS6 .mts from AF100 will not stop conforming
Jul 27, 2012 4:49 PM
I see tons of chatter about this issue over the years but no real resolution to the issue. I'm a recent convert from FCP/Avid. I have some .mts files from an AF100. I followed everyones advice and let the audio finish conforming before I started editing, but not only do the files need to be conformed every time I restart PP, but every time I switch a sequence! This is killing me. I have to open any clip I want to listen to in the source monitor to prioritize it in the conforming cue. I see the .pek and .cfa and .xmp files in the folder with the source media, but obviously things are not communicating. Any work arounds? Seems like this has been and issue since CS3 or 4, wish Adobe would have worked this out by now....I have updated to the most recent version of cs 6, mac os 10.6.8, Dual Quad Core Xeon with 32GB ram....
    Jul 27, 2012 10:20 PM   in reply to cowboymustache
    It appears to be an exclusive privilege of MAC users. Have never experienced anything like that, but then I'm on a PC of course.
    Jul 28, 2012 1:17 AM   in reply to Harm Millaard
    We see files being re-conformed over and over on both Windows and Mac platforms, although to be fair, not quite as bad as being described.  It does apear that if the source files are ever 'touched' by Premiere Pro (as in meta data etc updated) then if performs a reconform as if it was a new file.   Of course, an engineer could say that's not the cause and it's becauseof 'xyz' instead.  In fact, I wish they would
    It would be nice if someone from Adobe could let us know the reasons while any file gets reconformed so we could all stop doing what ever is causing it.  Please ?   Pretty please?
    Jul 28, 2012 9:47 PM   in reply to ExactImage
    Can you simply render and replace the audio (by starting to edit it in Audition then never really doing any editing - just closing Audition?
    Jul 29, 2012 2:16 AM   in reply to Steven L. Gotz
    Going via the menu:
    Clip --> Audio Options --> Render & Replace and it will achevie the same thing without launching Audition.
    Jul 30, 2012 10:35 AM   in reply to cowboymustache
    AVCHD is what had caused us the most problems in the past.... and it's happened with other NLEs too.  The answer has always been to render to a wave file at the appropriate sample rate (usually 48Khz).
