jquery: logic issue
Jul 28, 2012 4:31 PM
I've created a gallery but I am having some problems with getting it to tranistion properly.
The gallery has a row of thumbnails, and when you click on a thumbnail the lager appears.
they are both using css transforms to animate them.
click on the thumbnail they should both move up (translateY) the thumb disappearing, the larger image appearing(translateY).
I can get the thumbnails to work, but I can only get the initial lager image to work correctly.
I've been trying to figure out how two use two divs to transition them in and out. on a click the clicked image will move up while the other moves down.
I placed my code below. Any suggestions will be appreciated.
<!DOCTYPE html>
<html lang="en">
          <head>
                    <meta charset="utf-8" />
  <!-- Always force latest IE rendering engine (even in intranet) & Chrome Frame
                    Remove this if you use the .htaccess -->
                    <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
                    <title>gallery</title>
                    <meta name="viewport" content="width=device-width; initial-scale=1.0" />
  <!-- Replace favicon.ico & apple-touch-icon.png in the root of your domain and delete these references -->
                    <link rel="shortcut icon" href="/favicon.ico" />
                    <link rel="apple-touch-icon" href="/apple-touch-icon.png" />
                    <script type="text/javascript" src="jquery-1.7.1.min.js"></script>
                              var hld_one;
                              var hld_two;
                              $(function() {
                              $("a").click(function() {
                                        if ($('#holder_one').html()=='')
                                                  $('#holder_one').html('<img src="' + $(this).attr('datafld') + '" width="890" height="430">');
                                                  $(".sm_display").removeClass("animate_small");
                                                  $('#showcase #holder_one').addClass('animate_showcase_up');
                                                  $("#"+$(this).parents("div:first").attr('id')).toggleClass("animate_small");
                                                  hld_one="up"
                                                  hld_two='down'
                                                  return;
                                        if (hld_two='down')
                                                  $('#holder_two').html('<img src="' + $(this).attr('datafld') + '" width="890" height="430">');
                                                  $('#holder_two').css('z-index:1');
                                                  $('#holder_one').css('z-index:0');
                                                  $('#holder_one').removeClass('animate_showcase_up');
                                                  $('#holder_one').addClass('animate_showcase_down');
                                                  $('#holder_two').removeClass('animate_showcase_down');
                                                  $('#holder_two').removeClass('animate_showcase_up');
                                        var currnt_picID = $(this).parents("div:first").attr('id');
                                                  $('#showcase #holder_one').html('<img src="' + $(this).attr('datafld') + '" width="890" height="430">');
                                                  $('#showcase #holder_one').css('z-index:1');
                                                  $('#showcase #holder_two').css('z-index:0');
                                                  $(".sm_display").removeClass("animate_small" );
                                                  $("#"+$(this).parents("div:first").attr('id' )).toggleClass("animate_small");
                                        var frnt_html = $('#front').html();
                                        var back_html = $('#back').html();
                                        if (frnt_html==""){alert('empty')}
                                        $("#"+$(this).parents("div:first").attr('id')).to ggleClass("animate_small");
                                        $('#showcase #front').html('<img src="' + $(this).attr('datafld') + '" width="890" height="430">');
                                        $('#showcase #front').toggleClass('animate_showcase_up');
                    </script>
                    <style type="text/css">
                                        margin:0; padding:0;
                              div, div, img
                              #display_container
                                        margin:auto;
                                        position:relative;
                                        width:900px;
                                        background-color:gray;
                                        padding: 15px;
                              #showcase
                                        margin: 0 auto;
                                        width:890px;
                                        height:430px;
                                        margin-bottom:15px;
                                        background-color:black;
                                        border: solid 1px white;
                              #holder_one
                                        background-color:red;
                                        width:890px;
                                        height:430px;
                                        float:left;
                                        position:relative;
                                        z-index: 1;
                                        top:435px;
                                        left:700px;
                                        -webkit-transition:All 2s cubic-bezier(0.075, 0.820, 0.165, 1.000);
                              #holder_two
                                        background-color:blue;
                                        width:890px;
                                        height:430px;
                                        position:relative;
                                        z-index:0;
                                        top:435px;
                              #gallery
                                        margin: 0 auto;
                                        padding:5px 0;
                                        width:890px;
                                        height:100px;
                                        overflow: hidden;
                                        z-index:1;
                                        clear: both;
                              .sm_display
                                        display:inline-block;
                                        margin:0 5px;
                                        width: 162px;
                                        height:100px;
                                        border: solid 1px black;
                                        opacity:.5;
                              .sm_display:hover
                                        opacity:1;
                               .animate_small
                                        -webkit-transform: translateY(-120px);
                               .animate_showcase_up
                                        -webkit-transform: translateY(-435px);
                                        -webkit-transform: translateY(435px);
                              opacity:0;
                    </style>
          </head>
          <body>
                    <div id='display_container'>
                              <div id='showcase'>
                                        <div id='holder_one' class=''></div>
                                        <div id='holder_two' class=''></div>
                              </div>
                              <div id='gallery'>
                                        <div class="sm_display" id='one'><a datafld="color.TIF"><img src="color.TIF"  width=" 162" height="100"></a></div>
                                        <div class="sm_display" id='two'><a datafld="deco.jpg"><img src="deco.jpg"  width=" 162" height="100"></a></div>
                                        <div class="sm_display" id='three'><a datafld="jill.jpg"><img src="jill.jpg"  width=" 162" height="100"></a></div>
                                        <div class="sm_display" id='four'><a datafld="vince.jpg"><img src="vince.jpg"  width=" 162" height="100"></a></div>
                                        <div class="sm_display" id='five'><a datafld="jillvince.jpg"><img src="jillvince.jpg"  width=" 162" height="100"></a></div>
                              </div>
                    </div>
          </body>
</html>
