Hello forum members:
1) I have a main movie that loads an external movie with this code:
var loader:Loader = new Loader();
loader.load(new URLRequest("lessons/lessona/lessona.swf"));
addChild(loader);
loader.y=0;
var myTween:Tween = new Tween(loader, "x", Strong.easeIn, 1500, 0, 1, true);
2) The loaded movie attaches a movieclip from the loaded movieclip library with this code:
var mc:alert_mc=new alert_mc();
mc.x=320;
mc.y=210;
addChild(mc);
3) From the attached movie clip I am trying to remove the attached clip and the loaded movie (and return to my main movie) with this code when the user clicks yep_btn but it is unsucessful (it does not unload or return me to my main movie)
nope_btn.addEventListener(MouseEvent.CLICK, cancelunloadexitb);
yep_btn.addEventListener(MouseEvent.CLICK, unloadexitb);
function cancelunloadexitb(e:MouseEvent):void {
this.parent.removeChild(this);
function unloadexitb(e:MouseEvent):void {
Loader(this.parent).unloadAndStop();
How do I get back to my main movie? Any ideas... Thank you
Trace the chain to see where you are... if the buttons are in the attached library clip then their parent is the clip, and parent.parent should be the lessona swf. So, try something like so until you derive the right object:
trace(parent);
trace(parent.parent);
//etc
If mc is a child of lessona.swf, then its parent is not the Loader.
mc is a child of lessona.swf.
How can I access the Loader of lessona.swf from the mc child?
trace(parent);
//etc
The trace generates this:
[object MainTimeline]
[object Stage]
It does not trace from the main Movie only from the loaded movie
Thank you. You led me in the right direction.
I used this: Loader(this.parent.parent).unloadAndStop();
Also very important not to have two movieclips with same name in library
If mc is a child of the loaded swf, then the loaded swf is the parent of the child. If the code that is trying to target the Loader is in the mc timeline, then the Loader should be one parent away from the swf, so 'parent.parent' should target the loader
