AVDoc Open method & enhanced security/protected view
Jul 30, 2012 7:18 AM
I have recently inherited some code that merges two PDFs together using OLE automation.
I've found that the code works with Acrobat X if Enhanced Security is disabled but it fails to open a PDF from a file if Enhanced Security is enabled (Protected View is set to All Files).
I've traced the problem down to the Open method of the AVDoc class. Open always returns 0 even if the file exists.
Is this the expected behaviour if Protected View is enabled? Are there any work-arounds?
TIA
Julie
    Jul 30, 2012 7:57 AM   in reply to juliepeck11
    Yes, this is expected behavior (as described in the Acrobat SDK documentation for Protected View).
    Aug 1, 2012 4:56 AM   in reply to juliepeck11
    Just turn off the user preference.  I assume it’s a controlled environment in which your application is being deployed.
    Aug 1, 2012 5:24 AM   in reply to juliepeck11
    Reader’s Protected Mode (where whitelists are used) is NOT the same as Acrobat’s Protected View.   You can’t use OLE with Reader, only Acrobat.
    Aug 2, 2012 4:51 AM   in reply to juliepeck11
    Yes, you can use the customization wizard to set Privildged Locs.
