DirtyHarry
ACF internal webserver running on port 80?
Jul 30, 2012 8:06 AM
Is it possible to change to port of the internal ACF 10 Tomcat (Coyote) webserver to port 80?
My attempts where not successful, after changing the value from 8500 to 80 ACF doesn't start anymore - and no logfile is written.
The port is not reserved.
    Jul 30, 2012 4:55 PM   in reply to DirtyHarry
    Jul 31, 2012 4:48 PM   in reply to DirtyHarry
    What hint would you like? It refers exactly to how to change the port. (Thanks for the mention, Carl.)
    Now, maybe, Harry, you mean “CF does not come up when I change its internal web server port 80”.  That could very well be because something else on the box is already using port 80, which is the default port for web servers like Apache and IIS. Do you mean you want hints how to detect what may be using that port? There are many, many ways to do it. It would help if you’d tell us if you’re on Windows or Linux. Similarly, if it is the other web server, you’d just want to stop it.
    But then that begs the question: why are you trying to do this (change CF’s internal web server port to be 80)? If you read the blog entry Carl pointed you to, you saw I make the case for why one might consider using the internal web server instead of an external one (since it, the Tomcat web server, is far better than the old JRun web server), but I still make the point (more than once) that I’m not saying that one SHOULD change it.
    So again, please tell us more, so that we can best help you.
    /charlie
    Aug 1, 2012 4:08 PM   in reply to DirtyHarry
    Perhaps there is an error we just not seeing it. Try start CF10 from CMD (as administrator?) prompt. Eg:
    CMD
    CD \ColdFusion10\cfusion\bin
    ColdFusion10\cfusion\bin>CFSTART
    Any interesting warnings or errors?
    HTH again, Carl.
    Aug 18, 2012 2:46 PM   in reply to DirtyHarry
    “Harry”, I really do think that this is your bottom line problem: something else is holding port 80.
    Now, as for why your netstat says you have nothing else running on that port, well, here’s one thought: what if something’s listening on an IPV6 address? Is it possible that would not show up with the search filter you did (findstr 0.0:80). What if you use findstr ::]:80 instead? That’s just a guess. I don’t know for sure that something could show up as IPV6 and not IPV4, but it’s worth ruling out.
    Better still, as for finding what ports are being listened on, I can’t recommend enough the free tool, curports. It presents a nice, simple, sortable display:
    http://www.nirsoft.net/utils/cports.html
    BTW, something that I often find is running on port 80 and blocking things for people, that they would never expect, is Skype. For more, see http://www.mydigitallife.info/disable-skype-from-using-opening-and-lis tening-on-port-80-and-443-on-local-computer/.
    Looking forward to getting to the bottom of whatever is holding you up.
    /charlie
    Aug 18, 2012 2:48 PM   in reply to DirtyHarry
    (Bummer, I had offered this reply first by email (before my other reply today, showing up below here in the forums), but somehow it was rejected by the forum mail server, which is odd, since I replied to this message from Harry the same way I had replied to the "later" note.)
    Sorry for the delay in responding, “Harry”. Yes, I have indeed configured CF10 to run its internal web server as port 80. And it’s running successfully as I speak. Here’s the line from the C:\ColdFusion10\cfusion\runtime\conf\server.xml:
    <Connector executor="tomcatThreadPool" maxThreads="50"
                   port="80" protocol="org.apache.coyote.http11.Http11Protocol"
                   connectionTimeout="20000"
                   redirectPort="8445" />
    And here’s my netstat (per the variant you showed you were using in your later note in this thread):
    TCP    0.0.0.0:80             0.0.0.0:0              LISTENING       9016
    And that 9016 is indeed CF10 (tasklist | findstr 9016):
    coldfusion.exe                9016 Services                   0    496,572 K
    Finally, here is the CF10 internal web server access log (C:\ColdFusion10\cfusion\runtime\logs\localhost_access_log.2012-08-18 .txt) entry showing that a test request I did just now was indeed run via that web server:
    0:0:0:0:0:0:0:1 - - [18/Aug/2012:17:20:47 -0400] "GET /test2.cfm HTTP/1.1" 200 78987
    So yes, it can and does work to use the internal web server as port 80.
    About your later note saying CF will not start if you try to configure this, because it conflicts with something already running on port 80, I really think that’s your bottom line problem (something else is holding the port). But as for your challenge to see what that could be, I’ll reply separately to that note.
    /charlie
    Aug 20, 2012 9:49 AM   in reply to DirtyHarry
    Thanks for the update. But are you saying it was running in such a way as to “hide” its use of port 80 from tools like cports and netstat? Either way, sure, knowing of yet one more thing to “try” if all else fails is helpful. Thanks for sharing it.
    /charlie
    Aug 22, 2012 1:30 PM   in reply to DirtyHarry
    Maybe the IIS or Apache services start before TrendMicro, so that when they normally run, it (TM) grabs a different port because it finds port 80 taken.
    But then if you stop them (IIS and Apache) and either restart the box, or perhaps rerun TM or it reruns on its own, it then grabs the port while it’s “open”. So that by the time you then try to run CF to use port 80 with its internal server, it cannot because now TM’s taken it. Just guessing. There HAS to be an answer, of course.
    /charlie
