I need to create an Enterprise Signed Build (for internal company distribution). I have created 2 renditions (for iPad 2 and 3) and exported out of Folio Producer.
What kind of "Viewer Type" should I select...Built-in Single issue, multi-issue, etc.?
I only see one field to upload a Folio File, but I have exported 2 renditions.
I am concerned that if I need to select "Single Issue" I cannot use my 2 renditions. I have a number of Pan and Zoom overlays in my pub, and want them to display properly (I used 2 differently sized Pan/Zoom assets when creating my renditions).
Thank you.
http://help.adobe.com/en_US/digitalpubsuite/using/WS67cb9e293e2f1f6063 be51521300070dc55-8000.html
First of All, for creating Enterprise signed Builds you need DPS Enterprise Edition. If you have that, then you do not need to export folios, you can directly publish the folios as Public from Folio Producer (Title id in Viewer Builder) and publish both the renditions with same metadata and same product id. In Viewer Builder choose Enterprise signed build.
Thanks again for the input!
I'm encountering some issues at the end of the publishing process.
These are my settings for creating an enterprise signed build: Publish as Public and Free, Multi-issue, Enterprise signed build.
Does the Viewer Builder automatically find what I published in Folio Producer? My final .ipa file is only 3MB whereas the app I built is 312MB. Seems like that isn't right.
Tried dragging the .ipa file and mobileprovisioning files into iTunes, but when I sync my iPad I get this message: "The app was not installed on the iPad because the signer is not valid."
In a single issue app you add the folio hence the size of the app is larger.
Now with a multi issue app the content is provided through the distribution servers which display the folio from the Title Id that you have specified (using which you publish to the app ) so the size of the viewer is small and hence you do not need to worry about the same.
Regarding the error that you are getting, it seems that you need to recheck the certificates as that error directly is linked with the certificates that you have created and mentioning that the signing was not succesfull hence you were not able to instal the .ipa file
North America
Asia Pacific
