mmoore0904
Is there anyway to create a watched/monitored folder for actions (similar to distillar for PDFs)
Jul 31, 2012 3:04 AM
Tags: #web #cs5.5 #premium #batch #folder #actions #droplet #watched
Is there any way to set up a watched folder in Photoshop to automatically batch run an action on any image that is dropped into that particular folder?
Similar to how distillar works for PDFs.
I have Creative Suite Web Premium 5.5 so if any of the other packages in the suite will do the job please let me know as I can't seem to find it.
A droplet won't do the job as although the processing will take place on my machine - the image may be dropped into the folder by a colleague elsewhere.
Thanks.
    Jul 31, 2012 3:39 AM   in reply to mmoore0904
    G'day
    Untested, but a folder action attached to a desktop folder called something like "Drop Photoshop Files Here" and also a desktop folder call "Processed Folder" might do it, using this untested script.
    on adding folder items to this_folder after receiving list_of_files
              set ptdpf to path to desktop & "Processed Folder" as text
              tell application "Adobe Photoshop CS6"
                        repeat with this_File in list_of_files
      open this_File
      --do action <name of PS action> from <action set>
      close window 1
                        end repeat
              end tell
              tell application "Finder"
      move list_of_files to ptdpf
              end tell
    end adding folder items to
    Jul 31, 2012 7:35 AM   in reply to OzSanta2
    I've done some investigating, and Photoshop can Batch Process the files.
    You'll need to create three folders on your desktop...
    Photoshop Processing
    Processed Images Folder
    Processed Stored Folder
    Attach the following script to the first folder. Save the script in 'Library/Scripts/Folder Action scripts' and then right click on the Folder 'Photoshop Processing' and attach the script.
    I AM asssuming your running a Mac with all this. I'm also assuming the original files are left untouched in the first folder, and need shifting after they're processed. I'm running a trial version of CS6 on my iMac, and it tells me Batch Processing isn't available, so I can't test it.
    on adding folder items to this_folder after receiving PhotoshopFiles1
                        set ptd to path to desktop as text
                        set ptdpp to ptd & "Photoshop Processing" as text
                        set ptdpif to ptd & "Processed Images Folder" as text
                        set ptdpsf to ptd & "Processed Stored Folder" as text
                        set fileToLog to (ptdpif) & ":Photoshop_Batch_Errors_Log.txt" as text
                        set PhotoshopFiles to document files of folder ptdpp as alias list
      say (count of PhotoshopFiles)
                        if not (exists file fileToLog) then
                                  make new file at ptdpif with properties {name:"Photoshop_Batch_Errors_Log.txt"}
                        end if
              end tell
      activate
                        set display dialogs to never
      batch "Wood Frame - 50 pixel" from "Default Actions" from files PhotoshopFiles with options {destination:folder, destination folder:alias ptdpif, error file:alias fileToLog, macintosh compatible:true, file naming:{document name lower, extension lower}, suppress open:true, override save:true}
              end tell
      move PhotoshopFiles to ptdpsf
              end tell
    Aug 1, 2012 2:51 AM   in reply to OzSanta2
    According to the Applescript Users Group, Batch hasn't worked since at least CS4, that's why the error messages. Darn Adobe, they  include it in their Scripting Guides.
    This works, but depending on the action, you might get a dialog box that, again, Adobe in their stupidity have decided can't be turned off with scripting. This also renames duplicate files.
    Regards
    Santa
              try
      --set ptdpp to ptd & "Photoshop Processing" as text
                        set ptdpp to this_folder as text
                                  if not (exists folder ptdpif) then
                                            make new folder at folder ptd with properties {name:"Processed Images Folder"}
                                  end if
                                  if not (exists folder ptdpsf) then
                                            make new folder at folder ptd with properties {name:"Processed Stored Folder"}
                                  end if
                                            make new file at folder ptdpif with properties {name:"Photoshop_Batch_Errors_Log.txt"}
                                  end if
                                  set PhotoshopFiles to files of folder ptdpp as alias list
                        end tell
      delay 4
      activate
                                  repeat with this_File in PhotoshopFiles
                                                      set file_Name to name of this_File
                                                      set file_Extension to "psd" --default Save name extension of this_File
                                                      set file_Name2 to characters 1 through -((count of file_Extension) + 2) of file_Name as text
      display dialog file_Extension
                                                      set file_to_save to (ptdpif & ":" & file_Name2 & "." & file_Extension as text)
                                                      set x to 1
                                                      repeat
        if not (exists file file_to_save) then exit repeat
        set file_to_save to (ptdpif & ":" & file_Name2 & " " & x & "." & file_Extension as text)
        set x to x + 1
                                                      end repeat
                                            end tell
      open this_File
      --set display dialogs to never
                                            try
      do action "Wood Frame - 50 pixel" from "Default Actions" without notifiers enabled and display dialogs -- < this particular action brings up a dialog box which can't be addressed with Applescript
      save current document in file file_to_save with copying -- < set to 'without copying' if original files not required
                                            on error errmsg
      display dialog errmsg -- < write to ":Photoshop_Batch_Errors_Log.txt" here
                                            end try
                                            try
      close document 1 saving no
                                            end try
                                                      set file_to_store to (ptdpsf & ":" & file_Name2 & "." & file_Extension as text)
                                                      set file_Extension to name extension of this_File
                                                      set x to 1
                                                      repeat
        if not (exists file file_to_store) then exit repeat
        set file_to_rename to (ptdpsf & ":" & file_Name2 & " " & x & "." & file_Extension as text)
        if not (exists file file_to_rename) then
        set name of file file_to_store to (file_Name2 & " " & x & "." & file_Extension as text)
        exit repeat
        end if
        set x to x + 1
                                                      end repeat
                                                      try
      move this_File to folder ptdpsf
                                                      on error
        try
      move this_File to folder ptdpsf with replacing
        on error errmsg
        end try
                                                      end try
                                            end tell
                                  end repeat
                        end tell
              on error errmsg
              end try
