Bridge CS6 crashing on output
Jul 31, 2012 7:59 AM
Here is the error I am getting everytime I switch to "Output" in Bridge CS6:
TypeError: undefined is not an object:
onResizeO
buildUIStack(true, "Cabinet")
buildUIStack(JTabbedPalette:[object
TabbedP alette II. true, 'Cabinet')
switch T o([T abbed Palette: [object
Tabbed Palette]],[G roup: [object Grou p]],true)
AmgOesignWindow([TabbedPale tte:[object
TabbedPalette]J.[Group:[object Grou p]],true)
populate([Grou p: [object Group]], true)
When I try to create a pdf, it gives me the error: Out of memory. I have a ton of memory on my machine, so that's not an issue.
    Jul 31, 2012 8:17 AM   in reply to Matbathome
    How is the cache and other disk space?  Out of memory is kind of generic and does not mean just RAM.
    Nov 25, 2012 12:17 PM   in reply to Matbathome
    I've been getting the "undefined is not an object" when making a PDF from a group of jpg files. I tried to do a large number of them at once and got the error so I broke the group down into smaller chunks. That worked out fine but when doing one chunk I get the error. So there must be an problem with one of the files I guess. Unfortunately the error box doesn't say anything else. Pretty helpful.
  • Omke Oudeman
    Nov 27, 2004
    Nov 25, 2012 12:50 PM   in reply to jnwbr
    Thats almost always for every app the case I'm afraid. The quickest way is to divide the group with the files containing the problem in half, and again and again until you finally end up with the problem file (if it is one...)
    Also a look at the previews or open the lot in PS might share some light.
    And just out of curiosity, what large numbers are you talking about and how have you set the settings for the Output Module?
    Nov 25, 2012 2:42 PM   in reply to Omke Oudeman
    I'm doing contact sheets of about 8800 smallish jpgs. 36 images per page/150 ppi.
    I thought I had it narrowed it down to 1 jpg file which was at about the 5500 mark. But trying what I had already OKd still resulted in an error. Too frustrating and time wasting to continue.
  • Omke Oudeman
    Nov 27, 2004
    Nov 25, 2012 2:54 PM   in reply to jnwbr
    I can imagine that myself
    On the other hand, 8800 is indeed a large number and Bridge is not known for multitasking and can be very critical in processor needs. It might be just a bit to much for one go, building all that thumbs and creating PDF etc. etc.
