I keep noticing this so I thought I would ask.
Windows 7 cs5.5
After I drag a clip from my source monitor into my timeline it looks normal.
In the timeline area, I drag the start of the clip to where I want my in point to be. Then do the same with the out point on the clip.
Clip looks fine in my program monitor.
I then drag the clip on the timeline over to the left behind the clip in the sequence (where I want it to go).
Suddenly the clip is darkened or completely black in the program monitor.
I also noticed once - I unlinked the video and audio in a clip. Then extended the audio to the left on the timeline.
Basically making the audio 4 seconds longer than the video. The clip in the program monitor turned Black during playback.
Just wondering what causes this and how to avoid?
It's on the same line in the timeline.
If you have one video/audio track on the timeline. You keep adding clips one right after another on that same track.
When I add a clip, then decide to shorten it by physically moving the cursor over the front and end of the clip then the clip turns darker or completely black in the program monitor.
Sorry ...dont know what is going on in your issue but something that I notice is your monitors are both running at 100% ....and I would expect to see them set as "FIT"
What is the source footage and what is the project setting?
BTW - my observation is unlikely to have anything to do with your issue.
I agree, that this looks like an accidental Opacity change from 100%.
Unfortunately, it is really tough to see the Opacity "rubberband" on the Clip, in this photograph.
However, if the OP looks at the yellow-orange line, with the Fixed Effect>Opacity selected for display, it should be easy to see any change in the Clip that was moved vs the first one, that was not moved.
One can also look at the Clip info header, with Opacity selected, or in the Effects Control Panel>Opacity, with the Clip Selected.
Thanks - it is an accidental Opacity change.
Appreciate the help. I tried moving the yellow line on the clip and it did darken an otherwise normal clip - so the accidental opacity change is definitely the problem..
Now I can make sure I stop doing that when I grab a clip to move it. Otherwise that would have drove me crazy to have it keep happening.
I'll have to be sure to grab the clips at the top when I move them on the timeline to avoid that yellow line for opacity.
Is that still in CS6 (the opacity line on clips?). I just recently purchased the upgrade but haven't installed until I finish a couple of smaller projects.
North America
Asia Pacific
