Script Dialog Flashes Briefly Then Disappears
Jul 31, 2012 2:00 PM
Tags: #javascript #scripting #extendscript #automation
Hi All,
I'm trying to write a script for indesign CS6 mac which will open a panel and let me interact with it while indesign is open. I've tried several different code approaches, and with all of them, the window briefly opens and then closes immediately. If I add an infinite loop into the mix, it does not close, but remains  unresponsive. This is one version of the code:
#target inDesign
#targetengine main
function myScript(thisObj) {
          function myScript_buildUI(thisObj) {
                    var myPanel = (thisObj instanceof Panel) ? thisObj : new Window("palette", "My Panel Name", [0, 0, 300, 300]);
                    res="group{orientation:'column', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
                              myStaticText: StaticText{text:'StaticText Text'},\
                              myEditText: EditText{text:'EditText text'},\
                              myButton: Button{text:'Button Name'},\
                              myCheckbox: Checkbox{text:'Checkbox Name'},\
                              myRadioButton: RadioButton{text:'RadioButton Name'},\
                              myDropDownList: DropDownList{properties:{items:['Item 1 Name', 'Item 2 Name', 'Item 3 Name', 'Item 4 Name']}},\
                              myListBox: ListBox{properties:{items:['Item 1 Name', 'Item 2 Name', 'Item 3 Name', 'Item 4 Name']}},\
                              myGroup: Group{orientation:'row', alignment:['fill', 'fill'], alignChildren:['fill', 'fill'],\
                                        myGroupItem1: Button{text:'Hi'},\
                                        myGroupItem2: Button{text:'Hello'},\
                                        myGroupItem3: Button{text:'Goodbye'},\
                              myPanel: Panel{text:'Panel Name', orientation:'column', alignChildren:['right', 'fill'],\
                                        myPanelItem1: Button{text:'One'},\
                                        myPanelItem2: Button{text:'Two'},\
                                        myPanelItem3: Button{text:'Three'},\
                              myProgressBar: Progressbar{text:'Progressbar Name', minvalue:0, maxvalue:100, value:50},\
                    app.addEventListener("afterSelectionChanged", onSelChg, false );
                    //Add resource string to panel
                    myPanel.grp = myPanel.add(res);
                    // DropDownList default selection
                    myPanel.grp.myDropDownList.selection = 2;//Item index starts at 0
                    //Setup panel sizing and make panel resizable
                    myPanel.layout.layout(true);
                    myPanel.grp.minimumSize = myPanel.grp.size;
                    myPanel.layout.resize();
                    myPanel.onResizing = myPanel.onResize = function () {this.layout.resize();}
                    return myPanel;
          var myScriptPal = myScript_buildUI(thisObj);
          if ((myScriptPal != null) && (myScriptPal instanceof Window)) {
                    myScriptPal.center();
                    myScriptPal.show();
          myScript(this);
function onSelChg()
    alert("hi");
Any ideas?
Thanks!
    Jul 31, 2012 2:10 PM   in reply to natewhoscripts
    Du you have this?
    www.kahrel.plus.com/indesign/scriptui-1-11.pdf
    Jul 31, 2012 2:17 PM   in reply to natewhoscripts
    To get a palette to stay open, you need (apart from setting an
    independent target engine, which you've done) to run if from the
    InDesign scripts palette. If you try to run it from ESTK it won't work.
    Ariel
    Jul 31, 2012 2:20 PM   in reply to [Ariel]
    Good to know, Ariel.
    Jul 31, 2012 2:22 PM   in reply to [Ariel]
    Ariel
    This was my experience in CS4 and previous—it wouldn't work if the engine didn't already exist. In CS5 and above, though, it will create the engine on the fly even from the ESTK.
    OP should use a targetengine other than "main", though.
    Jeff
    Jul 31, 2012 2:34 PM   in reply to absqua
    Interesting. I haven't seen that mentioned anywhere. I'm still on CS4
    (and thoroughly enjoying it!).
    And yes, to be on the safe side avoid using "main" as your engine.
    Ariel
    Aug 1, 2012 3:02 AM   in reply to [Ariel]
    Page 2 in the guide Larry mentioned, Ariël
    Peter
    Aug 1, 2012 7:23 AM   in reply to Peter Kahrel
    Peter
    Maybe for version 12 you can put it on page 1
