venkatl
How to select group layer by a mouse click like in Photoshop?
Aug 1, 2012 1:04 AM
Tags: #select #object #set #group #fireworks_cs5
Hi
This probably may have a simple answer but unfortunately I'm not getting it
I new to Fireworks CS5 I worked on a layout and made several layers and then group some layers with their respective names in the layers panel, now I just want to select the group layer by a mouse click, the same we usually do in Photoshop by Ctrl+click or selecting from the dropdown to select layer or group.
    Aug 1, 2012 8:43 AM   in reply to venkatl
    First, remember that Photoshop and Fireworks use some different terminology. In Photoshop, a single element is called a layer, whereas in Fireworks, it's called an object (e.g., bitmap or vector). In Photoshop, a folder is called a group, whereas in Fireworks, it's called a layer. Fireworks also has something called groups, too, where multiple objects can be combined into one unit, so to speak. To group multiple objects, choose Modify > Group (or Command-G). This can easily be undone with the Ungroup command, if needed.
    Groups can be quickly selected on the canvas with the Pointer tool. The objects within the group can be selected individually with the Subselection tool.
    Layers are a different story. I think the only way to select all the items in a layer is to use the Layers panel. If you click on the Layer name or folder icon, you'll select all the visible objects in the layer. Oddly, sublayers seem to be excluded from this, and I cannot understand why. But similarly, you can click on a Sublayer name or folder icon to select all the objects contained within the sublayer.
    Finally, there's also something called the Select Behind tool. I think it allows one to toggle a selection between overlapping objects on the canvas. (I don't actually use this tool much.)
