I'm trying to get a simple modal popup window working via the Arbitrary HTML facility in Muse but am having problems.
I've tried this one http://www.ericmmartin.com/projects/simplemodal-demos/ and this one http://www.html-form-guide.com/contact-form/simple-modal-popup-contact -form.html without any luck.
Has anyone else had any success? Is there chance of a widget to do this?
Hi Rory_M,
I'm not sure how you host your Muse project but if you host it with BC then these solutions won't work because BC is not allowing you to run server side code. If you host it on your own web server then you should run PHP, and just make sure that you put in the "Insert HTML..." function what it needs to render the forms and to function.
I hope this help,
Cristian
Thanks for your response Cristian. We're not using BC because we need to run server side code on other areas of our site, so we are hosting the site ourselves. PHP is enabled on our hosting. I have spent quite a bit of time trying to get both of those modal solutions working within Muse and was hoping someone more knowledgeable than I am with HTML/CSS/PHP could have a look and see if they could get it working. Modal popups are kind of a big deal after all.
North America
Asia Pacific
