Configure Visual Basic 2010 Express for writing plugins. Beginners guide to SDK :)
Aug 1, 2012 7:09 AM
Tags: #start #guide #begin #express #beginners #visual_studio #sample_project
I decided to write this because I wasted a lot of time trying to just be able to compile the example files.
Seems many people have problems at this stage, so these are my experiences:
1. Install VB 2010 Express - find the latest installer on Microsoft site - you can do it
2. Install the Windows 7.1 SDK - you need this to be able to compile x64 code in the free VS 2010 version
http://msdn.microsoft.com/en-us/windowsserver/bb980924.aspx
3. DO NOT INSTALL VB2010 Express Service Pack 1.
This is very important - it will break the 64 bit compilers from 7.1 SDK. And no, the update to the SDK that microsoft released to deal with this very issue does not work, you'll be able to compile the aex files but for some reason AfterEffects doesn't load them - no errors no nothing.
When the ServicePack for VS 2010 shows up in windows update - right click it and clik "Hide this update". This way the SP1 won't install untill you manually tell it to
4. Set the system variable for AE plugin output directory - see the SDK pdf file for instructions.
5. Open Build All solution in VS.
You'll go through the wizard to convert it to a new version, don't worry.
6 Now, unfortunately, with each project from the examples, if you want to compile it, right click the project --> Properties
Under Configuration Properties --> General change the setting Platform Toolset from "v100" to "Windows7.1SDK"
That's it.
You will get errors during compilation, but it's just about the fact, that you're compiling a dll file, but the extension is aex so the compiler is a little suspicious.
When you open the BuildAll solution again you'll get some erros about VS not supporting directories in solutions, but that doesn't seem to interrupt anything, so whatever
If anyone has something to add, please do
    Aug 10, 2012 6:43 PM   in reply to kaczorefx
    Dude, that is sweet. So AEX file using the .NET framework?
    I gotta check it out when I have the time. I did get the VS 2012 RC running on Windows 8 to compile the examples - but didn't really examine it much.
    Yeah, I'm new to plug-in development here, and would love not be forced to retrogress to C...
