Friends,
You can create shortcuts for character styles and paragraph styles by hitting OPTION + a number on the KEYPAD.
You might think there are only ten options, but you can also use other combinations, like COMMAND + OPTION + a number on the KEYPAD.
Anyone else know other ways?
Styles can be set to any combination of Option/Alt + NumPad. On a PC you can combine it with Ctrl for more options, and on a Mac you can combine Cmd and/or Shift.
Thats it, should be enough combos to last all your styles. For more info on this, check out this document: http://help.adobe.com/en_US/indesign/cs/using/WS9D351498-DAAC-4be1-B4B 8-2B6C72FF6CEDa.html#WS60910FA3-2BD7-449d-9904-05CFA551665Da
But the problem with setting keyboard shortcuts for styles is that they don't work on a lot of modern laptops (no numeric keypad).
So for me it's better to use the Quick Apply method. I also have trouble memorizing arcane shortcuts like that. It's easier to use the mnemonic of named styles with Quick Apply.
A useful trick that popped up elsewhere on this forum is makin' use of a simple one-line script to apply a style (use Google to locate it).
It does not do anything else useful but applying a style, BUT you can assign any shortcut combo to a script! (With some sleight of hand it's even possible to assign usually un-assignable combos such as Alt+N -- on a Windows machine :-)
As a habit I always tap Esc before hitting the W key.
Yes, this is good advice.
I usually use the "Deselect all" command, which I have programmed to SHIFT + APPLE + A, but sometimes this doesn't work, whereas ESCAPE KEY always works.
I wonder why "Deselct all" doesn't always "deselect all," yet ESCAPE KEY does . . . anyone know?
North America
Asia Pacific
