How to fade out a reflection from 2 directions?
Aug 1, 2012 9:20 AM
Using CS6 on Windows 7. I've got a product photo of a product with square corners and the shot is taken on a angle so that a corner is pointed out towards you with 2 sides going away from you. I've created a copy of the layer, flipped it vertically and lowered the opacity to create a reflection. I then added a layer mask to the reflection layer and then a gradient to fade out the relection to solid white on 1 side of the product. But I need to apply a gradient to the other side of the product to fade out its reflection, but when I do this, it removes the first gradient. How can I fade out both sides of my
reflection? Thanks.
Mark
    Aug 1, 2012 9:43 AM   in reply to mc_mark
    If you want to maintain two masks affecting one layer then put one gradient in the layer's mask, put the layer into a layer group and put the second gradient in the group's mask.
    Alternatively, you can combine gradients by using different blending modes. The Gradient Tool options bar has a blending mode control for the next gradient to be drawn. You can also build a mixed gradient in layers, blending the layers, then stamp these layers into one layer and copy that layer into a mask. I recommend Gradient Fill layers (Layer > New Fill Layer > Gradient...) for making gradients which you can repeatedly tweak now and later.
  • Noel Carboni
    Dec 23, 2006
    Aug 1, 2012 12:24 PM   in reply to mc_mark
    An easy way to limit a gradient to part of an image is to make a selection first, then paint the gradient in it...
    Just to toss out some visual ideas...
    http://Noel.ProDigitalSoftware.com/ForumPosts/CubeWithReflection.psd
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 1, 2012 5:38 PM   in reply to mc_mark
    I duped the cube layer, rasterized it, deleted all but the two faces, flipped vertically via Edit -Transform, then used Edit - Transform - Distort on each side separately to make the edges line up.
    I just selected each side individually and rendered white to black gradients at near right angles into the layer mask.
    -Noel
