galleonsboy
Interactive pdf problems
Aug 2, 2012 4:34 AM
Tags: #problem #pdf #interactive
Hi There
I have just upgraded from CS5.5 to CS6. The problem is that all my 5.5 indesign templates with hyperlinks do not export properly in CS6. When I create an interactive pdf from the template in CS6 I seem to be able to click the first couple of links (any links) which will work, but  after that all subsequent links will not work. In the acrobat file the links are definitely there but they appear to be hidden. When I click on them with the select tool the properties box for the name field is blank. When I put some text in here it magically comes to life in the acrobat file. I am working on an I5 Imac.
Has anyone else had this problem?
    Aug 2, 2012 5:40 AM   in reply to galleonsboy
    Did you inspect the hyperlinks in the Hyperlinks Panel after converting to CS6?
    Are there any differences in the target URLs?
    If so, read this post:
    http://forums.adobe.com/message/4463255#4463255
    Uwe
