• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Create CSV file from a query?
Guest
Aug 02, 2012 Aug 02, 2012
Greetings
I am attempting to create a csv file from a query that would pop up for downloading.
I found this code:
<!--- Create the file with column headers. It is crucial that you have all the outputted text on one line with no spaces between the comma and the next column header.--->
<cffile action="write"
file="C:\TEMP\Analysis.csv"
output="Assigned Technician,Received Date,Received Time,Priority,Due Date,User Name,User Office,Assigned Date,Assigned Time,Completed Date,Completed Time,Hours to Complete,Description"
addnewline="yes">
<!--- Output the contents of the qryResults query ---> <cfoutput> <cfloop query="qryResults">
<!--- Append (Insert) the contents of the query into the already created CSV file. Make sure that you keep all the output on one line exactly like the column header--->
<cffile action="append"
output= "#(tech_lname)#, #TRIM(queue_dte)#, #TRIM(queue_tme)#,  #TRIM(queue_priority)#, #TRIM(due_dte#, #TRIM(user_name)#,  #TRIM(office_name)#, #TRIM(assign_date)#, #TRIM(assign_time)#, #TRIM(repair_dte)#, #TRIM(repair_time)#, # TRIM(repair_ttc)#, #Left(q_description,128)#"
addnewline="yes">
</cfloop>
</cfoutput>
<!--- This will pop up the file for downloading. You can open it in excel or any other text editing software. --->
<cflocation url="#your.url#/Analysis.csv">
Something is wrong with the query.
Here's the error:
Invalid CFML construct found on line 135 at column 105.
ColdFusion was looking at the following text:
The CFML compiler was processing:
An expression beginning with TRIM, on line 135, etc.
135 : output= "#(tech_lname)#
Any help would be appreciated....
Thanks in advance
Norman
TOPICS
Advanced techniques , Database access
Views
8.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
You are missing a closing bracket when trimming due_dte.
Votes
Translate
Translate
Report
Report
Guest
Dan:
Thanks for picking that up- I did put in the missing bracket, but still get the same error.
Votes
Translate
Translate
Report
Report
LEGEND ,
Given that the error is with your first field, it might have something to do with the brackets around the variable name.
By the way, did you know that cfoutput has a query attribute that makes this code redundant?
Also, your code will probably run faster if you use cfsavecontent to create a variable for your file contents.  Then you only have to write to it once.
Votes
Translate
Translate
Report
Report
Guest
Dan:
I was following the code as I found it- always nice to get a working solution already for use- so I didn't notice that, but it works, so I didn't mess with it.
Thanks Again.
Norman
Votes
Translate
Translate
Report
Report
Guest
Well, maybe I still have a question on the storage and reteival of the file via a URL link.
As you can see in the code, I was saving and appending the file in C:\TEMP which can't be accessed via a URL- I tried to store it via a fully qualified URL to a directory in the Web root- no luck.
I'll keep trying....
Votes
Translate
Translate
Report
Report
LEGEND ,
You can always use cfcontent to make the file available.
Votes
Translate
Translate
Report
Report
Guest
Dan:
Not to be a nudge, but what would that look like?
I found: <cfcontent file="#fPath#" deletefile="true" type="application/csv" />
Are you saying I could still store it in the user's C:\TEMP directory and that it would delete it from there when the user saves it wherever they want?
Norman
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
You can't store anything on the user's machine in any directory.  You can only store files on your application server.  For many developers, these are the same machine when they are writing code.  It sounds like you are one of these developers.
Votes
Translate
Translate
Report
Report
Guest
Dan- solved the problem- it was a bracket issue. Going blind in my old age- sorry.....
Thanks for your help.
Votes
Translate
Translate
Report
Report
Resources
Documentation
