Can I add a PLAY or Continue button in my Configurator Panel with a script?
Aug 2, 2012 1:29 PM
Some of my actions have a stop in them so that I can make some adjustments. How can I continue the action to complete it? Right now I need to go back to the regular action set and press the play button or have a shortcut key assigned to play. Can I add a PLAY button in Configurator?
    Aug 7, 2012 3:31 PM   in reply to ocphotog
    IWhy don't try to break apart script. Example:
    F6
    Create new layer
    Stop
    F7
    Opacity Change
    Stop
    F8
    etc
    Stop
    So try to shortcut after every stop.
  • JJMack
    Jan 9, 2006
    Aug 7, 2012 8:14 PM   in reply to ocphotog
    ocphotog wrote:
    Thanks but the action does most of that already. The action makes one last stop so that I can make a few last adjustments. I need a play button for the Configuator panel so that I do not have to go back to the action panel to press play.
    If the Stop is the last step in the action that action is actually done. I do not do panels but I would venture two guesses.
    1.) Put the stop message in the pannel instead and remove the stop that is in the action.
    2.) Leave the stop in the action so the user knows the process is done and they should make any final adjustment on ther own manually. Make the stop a stop with continue and add to the stop message click continue now.
