live in the now
How print exact dimensions of image?
Aug 4, 2012 5:30 PM
Tags: #size #print #cell
I have resized the image in Photoshop CS5 using Perfect Resize.  The image dimensions are 20.00 inches x 13.33 inches.
In the Lightroom print module, I chose these settings:
  • cell size to 20.00 in x 13.33 in.
  • All the margins are set to 0.00.
  • "Zoom to Fill" is not checked.
  • Page Setup:  17 x 22 paper.  Manual - rear-borderless (retain size)
The size printed is 20.5 in x 13.75 in
What should I be doing to get the print size to match the cell size of 20.00 x 13.33?
Information:
Lightroom version 4.1
Mac OS:  10.6.8
Printer:  Epson 3880
File:  Tiff
Thanks!
    Aug 5, 2012 12:59 PM   in reply to live in the now
    If I set up my Epson Stylus Photo R800 for borderless printing, it will scale the page a little larger than the real dimensions. EPSON says this is a feature to avoid thin white borders around the image because you will always have tolerances in the paper conveying system and in the position of the paper within the printer.
    So what you have to do is: Switch off the borderless printing. Then you won't have any scaling of the print. Unfortunatelly you will have the (in my case) 3 mm white borders all around because it's the maximum standard printing area. But as far as I can see you want to print smaller than you paper size anyway. So you shouldn't have trouble with this. So just switch off the borderless printing.
    Aug 7, 2012 4:43 AM   in reply to live in the now
    Why should I resize my image in Photoshop first?
    • I use my photo as it is, no resize in advance
    • Make sure that "borderless printing" is disabled in the printer driver
    • I set my cell size to the desired print size according to the aspect ratio of the image
    • I switch off the contour (German "Kontur") because this makes the image smaller again
    • Activate rotate & fit in (German "Drehen & Einpassen")
    • Activate zoom to fill if the image is too small in the size / resolution
    • Borders to minimum size (this comes from the printer driver, non-borderless printing -> max. printable area)
    • Then simply print the image.
    I tried it here with a 24 MPixel image from Sony Alpha 850, aspect ratio 3:2. I set the cell size to 150 x 100 mm and the printed image size is exactly 150 x 100 mm. There's no mismatch.
    Aug 7, 2012 2:54 PM   in reply to live in the now
    Well, don't write too general - that's confusing the people...
    I switched Lightroom to English language and checked the original designation:
    German "Kontur" means "Stroke Border". Of course, this has to be disabled.
    If we talk about print size then it won't matter what type of pixels you have. Lightroom calculates in the absolute ratio. If you tell lightroom to print in 400 dpi then it will scale the image to the right size. If the image is too small then you can use "Zoom to fill" and it will upscale the image. I haven't made a comparison if the print would be better if the upscaling was done by photoshop CS5.1.
    For the EPSON Stylus Photo R800 (and R1800) just disable "Borderless Printing".
    I guess this should help some people printing their photo in the real size.
  • Andrew Rodney
    Apr 16, 2009
    Aug 8, 2012 7:15 AM   in reply to live in the now
    live in the now wrote:
    1. Do we have enough pixels to get an acceptable print quality in a particular size?  For example, if I am taking a photo from an iphone and making a print size of 17 in x 22 in, then I go to Photoshop, and use the plug-in On-One Software’s Perfect Resize (formerly Genuine Fractals) to crop to a specified aspect ratio and resize.   Photoshop can do upsampling as well.  I am not sure if Lightroom can do this upsampling.
    It can and it can do this as well or better IMHO than Photoshop and GF (Prefect Resize) at least with proper capture sharpening in Develop and output to a print.
