how to add the Cloud Filter to Custom Shapes?
Aug 5, 2012 1:55 PM
Tags: #photoshop #help #draw #filters #cs6 #custom_shapes #cloud_filter #add_filter
Hello:        Level: Newbie    OS: Windows 7 64bit    Ps CS6
I am trying to make a sun. I used the elliptical marquee and was able to add the filter > render > coulds w/no problem
However, when I draw a custom shape and try to use the cloud filter it fills the whole layer not just the shape.
I've tried several things but nothing has worked.
Also, a box pops up that says the layer must be rasterized before using the cloud filter and then it fills the whole canvas/layer.
Any ideas? Thank you for your time
    Aug 5, 2012 2:38 PM   in reply to Kar209
    Photoshop filters operate on raster images (i.e. pixels) only. A couple of ways to get the necessary raster from a Shape Layer:
    1. Rasterize the SL, permanently converting it to a regular pixels layer (although you could keep a hidden copy of the SL in case you wanted to return to it).
    2. Convert the SL to a Smart Object which non-destructively encapsulates the SL and provides a raster representation on which filters can operate. This is advantageous in that you can edit the contained Shape Layer at any time, you can non-destructively transform (e.g. stretch or warp) the SO as many times as you want, and filters can be attached as non-destructive re-editable Smart Filters.
    For Clouds to be visible in only the existing pixels and not the empty region of a layer, make a mask for the layer: target the layer, Ctrl-click on its thumbnail to get a marquee of its pixels then click the Add Mask button at bottom of Layers panel. That's what I did below, but the mask could have been used as a Smart Filters mask which you can see as a white thumbnail.
    Aug 5, 2012 3:52 PM   in reply to conroy
    Instead of creating a Shape Layer then filling it with clouds, you could create clouds in a new layer then use a path as a Vector Mask for the clouds. Ctrl-clicking the Add Mask button makes it an Add Vector Mask button.
