i keep having this problem no matter how many times i reinstall and redownload.
i keep getting the installation failed message.
I have followed everything i can find to try and fix the problem and nothing is working
i have been trying to download the trial for almost a week now.
here's the message that comes up:
It appears you are having installation difficulties as opposed to problems downloading. I would recommend reviewing your installation logs manually. You can find details on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
If you are still having difficulty please use the Package for Support option and respond to this thread with your token number. I would strongly recommend though reviewing your installation logs first though as myself or other Adobe employees would be completing the identical steps as what is listed in the document.
I am having the same problem.
Bobbieturner what error messages did you uncover when you reviewed your installation logs?
Jeff I get as far as MAC HD/Library/Logs and then I dont see adobe...
Bobbieturner I would recommend contacting our support team then if you are facing difficulties with locating the installation log files.
2/5/2013 08:56:24.791 [INFO] PDAPP.AppletManager Loading progress1048576 out of 1280212
2/5/2013 08:56:24.792 [INFO] PDAPP.AppletManager Loading progress1114112 out of 1280212
2/5/2013 08:56:24.812 [INFO] PDAPP.AppletManager Loading progress1179648 out of 1280212
2/5/2013 08:56:24.814 [INFO] PDAPP.AppletManager Loading progress1245184 out of 1280212
2/5/2013 08:56:24.815 [INFO] PDAPP.AppletManager Loading progress1280212 out of 1280212
2/5/2013 08:56:25.146 [INFO] Deployment.D6FlexApplication Application load complete. Initializing the application
2/5/2013 08:56:25.149 [INFO] Deployment.ApplicationStartup Processing the application startup
2/5/2013 08:56:25.151 [INFO] PDApp.ExternalGateway Recieved Applet Loading Completion
2/5/2013 08:56:25.152 [INFO] Deployment.ApplicationStartup Communication Manager initialized. Loading ZString
2/5/2013 08:56:25.154 [INFO] ZStringLoader Trying to load ZString for preferred locale - en_US
2/5/2013 08:56:25.180 [INFO] ZStringLoader Locale set to - en_US
2/5/2013 08:56:25.180 [INFO] Deployment.ApplicationStartup ZString initialized with locale: 'en_US'. Starting deployment workflow.
2/5/2013 08:56:25.190 [INFO] Deployment.ApplicationStartup Font fallback applied is applicationFonts 'Lucida Grande, Segoe UI, Tahoma, _sans' inputControlFonts: 'Lucida Grande, Segoe UI, Tahoma, _sans'
2/5/2013 08:56:25.193 [INFO] Deployment.FetchMediaInformation Start fetching the payloads data
Tue Feb 5 08:56:25 2013 [INFO] PDApp.AppletManager - Loading Applet - DWA_Native for WindowID - 1
Tue Feb 5 08:56:25 2013 [INFO] DWANative - Build Version - 6.0.335.0
Tue Feb 5 08:56:25 2013 [INFO] DWANative - Logging Level verbosity Set to 4
2/5/2013 08:56:25.284 [INFO] DeploymentNativeApplet Media Signature found as {74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}
2/5/2013 08:56:25.285 [INFO] Deployment.FetchMediaInformation Summary file created for troubleshooting at path: file://///tmp/E8CFBF49-4B0A-4BFC-AAB2-4665AD34A932/summary.htm
2/5/2013 08:56:25.290 [INFO] DeploymentNativeApplet Setting System statistics data...
2/5/2013 08:56:25.292 [INFO] Deployment.DirectoryTokens Extracting tokens for mac
2/5/2013 08:56:25.294 [INFO] Deployment.DirectoryTokens Adding a token with name [AdobeProgramFiles] and value /Applications
2/5/2013 08:56:25.294 [INFO] Deployment.DirectoryTokens Adding a token with name [AdobeCommon] and value /Library/Application Support/Adobe
2/5/2013 08:56:25.295 [INFO] Deployment.DirectoryTokens Adding a token with name [Common] and value /Library/Application Support
2/5/2013 08:56:25.295 [INFO] Deployment.DirectoryTokens Adding a token with name [ProgramFiles] and value /Applications
2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [SharedApplicationData] and value /Library/Application Support
2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [SharedDocuments] and value /Users/Shared
2/5/2013 08:56:25.296 [INFO] Deployment.DirectoryTokens Adding a token with name [Utilities] and value /Applications/Utilities
2/5/2013 08:56:25.297 [INFO] Deployment.DirectoryTokens Adding a token with name [FontsFolder] and value /Library/Fonts
2/5/2013 08:56:25.297 [INFO] Deployment.DirectoryTokens Adding a token with name [Library] and value /Library
2/5/2013 08:56:25.298 [INFO] Deployment.DirectoryTokens Adding a token with name [LibraryPreferences] and value /Library/Preferences
2/5/2013 08:56:25.298 [INFO] Deployment.DirectoryTokens Adding a token with name [ScriptingAdditions] and value /Library/ScriptingAdditions
2/5/2013 08:56:25.299 [INFO] Deployment.DirectoryTokens Adding a token with name [UserPreferences] and value /Users/turtlebobbie/Library/Preferences
2/5/2013 08:56:25.299 [INFO] Deployment.DirectoryTokens Adding a token with name [UserCommon] and value /Users/turtlebobbie/Library/Application Support
2/5/2013 08:56:25.300 [INFO] Deployment.DirectoryTokens Adding a token with name [UserHome] and value /Users/turtlebobbie
2/5/2013 08:56:25.301 [INFO] DeploymentNativeApplet Checking whether the media with signature '{74EB3499-8B95-4B5C-96EB-7B342F3FD0C6}' has been run on this system
Tue Feb 5 08:56:25 2013 [WARN] DWANative - Could not retrieve media signature from the arguments.
2/5/2013 08:56:25.304 [INFO] DeploymentNativeApplet Fetching the setup manifest from media
Tue Feb 5 08:56:25 2013 [WARN] DWANative - Error in getting pdbGetInstallState 4
2/5/2013 08:56:25.599 [ERROR] DeploymentNativeApplet Payload list has no result top level tag: Return value is <error>Error in getting data from MDB</error>
2/5/2013 08:56:25.602 [INFO] AAMShared.DynamicViewMediator Showing screen with screenID : SCREEN_INSTALL_FAILURE
2/5/2013 08:56:25.674 [INFO] DeploymentNativeApplet Launch Successful
2/5/2013 08:56:25.684 [INFO] Deployment.ScreenNavigationCommand Approximate total time taken in startup is 531 milliseconds
Tue Feb 5 08:56:25 2013 [INFO] Setup - TimeLog: PDApp window came. Exiting
Tue Feb 5 08:56:25 2013 [INFO] Setup - ================= Exiting Installer with Code: 0 =================
Tue Feb 5 08:56:25 2013 [INFO] PIM - PIMSqlite closeDB status 0
Tue Feb 5 08:56:25 2013 [INFO] PIM - FREE PIM Instance ...
2/5/2013 08:57:49.517 [INFO] PDApp.HostMessageHandler Front applet found
Tue Feb 5 08:57:49 2013 [INFO] PDApp.AppletManager - Un-loading Applet - DWA_Native for window ID - 1
Tue Feb 5 08:57:49 2013 [INFO] PDApp.ExternalGateway - Callng the finalize function of the applet ID - DWA_Native
2/5/2013 08:57:49.546 [INFO] PDApp.HostMessageHandler Recieved force window close message
2/5/2013 08:57:49.547 [INFO] PDApp.HostMessageHandler Sending message to native
Tue Feb 5 08:57:49 2013 [INFO] PDApp.WindowManager - Destroying window with ID - 1
Tue Feb 5 08:57:49 2013 [WARN] PDApp.WindowManager - GetAPEWindowIDString failed, Unable to find PlayerRef!
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Last window destroyed quiting as event. Quiting application as an event (async)...
Tue Feb 5 08:57:49 2013 [INFO] PDApp.WindowManager - Destroying PDApp main window with ID - 1
Tue Feb 5 08:57:49 2013 [INFO] PDApp.WindowManager - DestroyAllAPEWindow failed, APE Window count is zero while destroying all APEWindow's
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating MessageQueueManager
Tue Feb 5 08:57:49 2013 [INFO] PDApp.AsyncMsgProcessor - Terminating AsyncMsgProcessor Message Queue
Tue Feb 5 08:57:49 2013 [INFO] PDApp.MessageQuequeManager - Message Queue Manager destructed
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating AppletManager
Tue Feb 5 08:57:49 2013 [INFO] PDApp.AppletManager - AppletManager destructed
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating WindowManager
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating NativeCommandHandler
Tue Feb 5 08:57:49 2013 [INFO] PDApp.ExternalGateway - NativeCommandHandler destructed
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating NativePlatformHandler
Tue Feb 5 08:57:49 2013 [INFO] PDApp.ExternalGateway - NativePlatformHandler destructed
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating ExternalGateway
Tue Feb 5 08:57:49 2013 [INFO] PDApp.ExternalGateway - ExternalGateway destructed
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Terminating APE
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Releasing all locks acquired
Tue Feb 5 08:57:49 2013 [INFO] PDApp - Quiting Application
