execute JSX in MAC
Aug 6, 2012 3:59 AM
Hi All,
I want to execute a .JSX file by using Mac Terminal Command like i am doing in MS Windows by using following cmmand:
     C:/ start illustrator.exe Script.jsx
its working fine but i want to do the same thing in MAC, if you have any idea about it please help me.
i am working on an Application in that I am using CS6 SDK to add some functionality in my Adobe Illustrator, but didnt find any method to execute JSX files directoly from VC++/CS6 SDK.
Please help me if you have any suggetion for me.
Thanks & Regards
Harsh
    Aug 9, 2012 2:44 AM   in reply to Harsh V Sharma
    There are following two ways to execute the script on Mac from terminal:
    01) The way it works on Win, same way it works even on Mac. But make sure that you have mentioned following statement at start of your Java Script:
              #target "Illustrator-16"
    02) Or if you do not want to do as mentioned above, you may provide command in terminal as follows:
             Open -a <full path of application> <Java Script Source"
    Hope this information helps.
    Dec 9, 2013 6:31 AM   in reply to Harsh V Sharma
    Hi Harsh,
    Please let me know the steps and syntax for  run the jsx file in command prompt on Windows OS.
    Satish
    Dec 9, 2013 3:12 PM   in reply to Satgates
    Doesn't he explicitly explain in his very first question how he does that? "... by using following cmmand:"?
    Did it not work for you?
    Dec 9, 2013 11:55 PM   in reply to [Jongware]
    Yes, that command open the indesign but not execute the jsxbin fine.
    Regards
    Satish
