KimNZ007
Can't Open .pdf Files
Aug 6, 2012 4:21 PM
Tags: #acrobat_9_pro
File association for .pdf is set to Adobe Acrobat 9.0 but .pdf files won't open.  Any ideas please?
    Aug 6, 2012 5:23 PM   in reply to KimNZ007
    How did you get the PDF files? They could be damaged. What happens when you try to open them?
    Can you open other PDF files?
    Aug 7, 2012 6:03 AM   in reply to Steve Werner
    Can you open the files from the file menu in Acrobat. That should give you some idea if they are damaged or if it is just an OS problem of the association. When you double click on the PDF, does Acrobat open? If not, you might need to check the link properties for the association.
