eaglefelix
help'
Aug 7, 2012 6:16 AM
hello i've changed to creative cloud but when i try premiere pro cs6 it asks to go online to verify says i've been accepted but if i try to open a project it goes back to the 'verify subscription' screen and does not open up? what's up? also do you need to remove cs5 premiere pro?
    Aug 7, 2012 11:21 AM   in reply to eaglefelix
    Are you choosing the option to License this software?  Do you have any other Adobe applications installed from the Creative Cloud?
    Aug 13, 2012 8:43 AM   in reply to eaglefelix
    I would recommend you first check your account at Adobe.com to verify your subscription is active.  Is it only Premiere Pro CS6 which is facing this difficulty or do you have other CS6 applications having the same problem?  Also is your CS5 software able to run successfully?  Was CS5 prepetual or did you have a subscription to CS5 as well?
    Aug 14, 2012 10:25 AM   in reply to eaglefelix
    Hmm it could be a problem with the permissions on your system to update the licensing.  Can you please try removing Premiere Pro and reinstall?
