AS3ForTheWin
MP3 Player Problems
Aug 7, 2012 8:55 AM
Tags: #as3 #button #xml #as3.0 #mp3
OK Guys, so I tried to make a MP3 player from a tutorial here http://www.republicofcode.com/tutorials/flash/as3musicplayer/
The player and the play, pause, next, previous etc. functions work just fine, but I want to make some improvements
1/I want to have a fully-functional loadbar and seekbar for the player
2/Could it be possible? I want the player to automatically plays a movie clip(that shows the next song in the playlist) at the last 10 second of every song
3/I want to merge both the play and pause buttons, so as to save space
Please guys I'm new to AS3 and all these event listeners thingy (because of my old computer, for the last 2 years I do Flash in AS2 - Flash 8 )
Here's the code:
import flash.net.URLLoader;
import flash.net.URLRequest;
import flash.events.Event;
import flash.media.Sound;
import flash.media.SoundChannel;
import flash.events.MouseEvent;
var my_songs:XMLList;
var my_total:Number;
var my_sound:Sound;
var my_channel:SoundChannel;
var song_position:Number;
var song_paused:Boolean;
var current_song:Number = 0;
var myXMLLoader:URLLoader = new URLLoader();
myXMLLoader.load(new URLRequest("playlist.xml"));
myXMLLoader.addEventListener(Event.COMPLETE, processXML);
function processXML (e:Event):void{
          var myXML:XML = new XML(e.target.data);
          my_songs = myXML.SONG;
          my_total = my_songs.length();
          myXMLLoader.removeEventListener(Event.COMPLETE, processXML);
          myXMLLoader = null;
function playSong(mySong:Number):void{
          var myTitle = my_songs[mySong].@TITLE;
          var myArtist = my_songs[mySong].@ARTIST;
          var myAlbum = my_songs[mySong].@ALBUM;
          var myURL = my_songs[mySong].@URL;
          title_txt.text = myTitle;
          artist_txt.text = myArtist;
          album_txt.text = myAlbum;
          if (my_channel){
          my_channel.stop()
          my_channel.removeEventListener(Event.SOUND_COMPLETE, onNext);
          my_sound = new Sound();
          my_sound.load(new URLRequest(myURL));
          my_channel = my_sound.play();
          my_channel.addEventListener(Event.SOUND_COMPLETE, onNext);
play_btn.addEventListener(MouseEvent.CLICK, onPlay);
function onPlay(e:MouseEvent):void{
          if (song_paused){
                    my_channel = my_sound.play(song_position);
                    song_paused = false;
          } else if (!my_channel){
                    playSong(current_song);
                    play_mc.gotoAndPlay(1);
next_btn.addEventListener(MouseEvent.CLICK, onNext);
function onNext(e:Event):void{
          current_song++;
          if (current_song>=my_total){
                    current_song = 0;
prev_btn.addEventListener(MouseEvent.CLICK, onPrev);
function onPrev(e:MouseEvent):void{
          current_song--;
          if (current_song<0){
                    current_song = my_total-1;
pause_btn.addEventListener(MouseEvent.CLICK, onPause);
function onPause(e:MouseEvent):void{
          if (my_channel){
                    song_position = my_channel.position
                    my_channel.stop();
                    song_paused = true;
play_mc.gotoAndStop(1);
  • kglad
    Jul 21, 2002
    Aug 7, 2012 9:40 AM   in reply to AS3ForTheWin
    1.  the sound class has a progress event and bytesLoaded/bytesTotal properties you can use for your loadbar.  it also has a length property and with the soundchannel's position property, you can create your playbar.
    2.  to autoplay, call onNext when a soundchannel soundcomplete event is dispatched.  (you can pass null or assign it as a default event in onNext.)
    3.  what's the problem?
  • kglad
    Jul 21, 2002
    Aug 9, 2012 10:39 AM   in reply to AS3ForTheWin
    typically you would have a progressbar with a child fill (eg, fillbar which is, by default, at 100%) and use:
    my_sound.addEventListener(ProgressEvent.PROGRESS, prog);
    function prog(e:Event):void{
              var loadtime:Number = my_sound.bytesLoaded / my_sound.bytesTotal; // not a suggestive variable name
      progressbar.fillbar.width =loadtime*progressbar.width;
    2. I mean at the last 10 seconds of every song there should be a movie clip instance playing that shows the next song's name, artist, album... not automatically play the next song when one ends?
    use a loop (like enterframe) to compare the sound's length property and the soundchannel's position property.
  • kglad
    Jul 21, 2002
    Aug 10, 2012 7:16 AM   in reply to AS3ForTheWin
    1. no.  you create your progressbar movieclip in the ide.  progressbar typically is a rectangle with a border and a fill.  convert the fill to a movieclip.
    2. a sound isn't going to dispatch an enterframe event.  use a displayobject (like a movieclip or sprite):
    this.addEventListner(Event.ENTER_FRAME,playprogressF);
    function playprogressF(e:Event):void{
    if(my_sound.length-my_channel.position<10000){
    yourmovieclip.visible=true;  // change this to suit your code.
  • kglad
    Jul 21, 2002
    Aug 10, 2012 11:02 PM   in reply to AS3ForTheWin
    did you pay attention to:
    if yes, copy and paste the code you used.
  • kglad
    Jul 21, 2002
    Aug 11, 2012 8:57 AM   in reply to AS3ForTheWin
    click file/publish settings/swf and tick "permit debugging".  retest.
    the problematic line number will be in the error message.  indicate which line of code that is.
  • kglad
    Jul 21, 2002
    Aug 12, 2012 9:53 AM   in reply to AS3ForTheWin
    you can't add the two event listeners (progressevent and enterframe) until your sound is instantiated.  ie, add those after your
    my_sound=new Sound()
    line of code.
  • kglad
    Jul 21, 2002
    Aug 12, 2012 8:21 PM   in reply to AS3ForTheWin
    use the trace function to determine where your code fails.
  • kglad
    Jul 21, 2002
    Aug 13, 2012 11:07 AM   in reply to AS3ForTheWin
    copy and paste your updated code and show what each trace returns.
  • kglad
    Jul 21, 2002
    Aug 14, 2012 3:19 AM   in reply to AS3ForTheWin
    you're nesting named functions.  that's not going to work.  and your code is a mess.  format it so it's legible and you can debug it.
    use:
    import flash.events.ProgressEvent;
    import flash.display.MovieClip;
    var my_sound:Sound;
    var current_song:Number=0;
    function processXML(e:Event):void {
        var myXML:XML=new XML(e.target.data);
        my_songs=myXML.SONG;
        my_total=my_songs.length();
        myXMLLoader=null;
    function playSong(mySong:Number):void {
        var myTitle=my_songs[mySong].@TITLE;
        var myArtist=my_songs[mySong].@ARTIST;
        var myAlbum=my_songs[mySong].@ALBUM;
        var myURL=my_songs[mySong].@URL;
        title_txt.text=myTitle;
        artist_txt.text=myArtist;
        album_txt.text=myAlbum;
        if (my_channel) {
            my_channel.stop();
        my_channel=my_sound.play();
        this.addEventListener(Event.ENTER_FRAME,playprogressF);
    function playprogressF(e:Event):void {
        var cpoint:Number=my_sound.length-my_channel.position;
        trace(cpoint);//trace returns a range of number counting down
        if (cpoint<10000) {
            next_mc.visible=true;
        trace(next_mc.visible);//trace always returns "true". that's expected because you never assign next_mc.visible=false.
    function prog(e:Event):void {
        var loadtime:Number=my_sound.bytesLoaded/my_sound.bytesTotal;
        trace(loadtime);//trace returns numbers ranging from 0.1 to 1
        progressbar.fillbar.width=loadtime*progressbar.width;
        trace(loadtime * progressbar.width);//trace always returns the original width of the progressbar: 250. that's impossible.
    function onPlay(e:MouseEvent):void {
        if (song_paused) {
            my_channel=my_sound.play(song_position);
            song_paused=false;
        } else if (!my_channel) {
    function onNext(e:Event):void {
        current_song++;
        if (current_song>=my_total) {
            current_song=0;
    function onPrev(e:MouseEvent):void {
        current_song--;
        if (current_song<0) {
            current_song=my_total-1;
    function onPause(e:MouseEvent):void {
        if (my_channel) {
            song_position=my_channel.position;
            my_channel.stop();
            song_paused=true;
