Problems using XFAConversionSettings renderAtClient in ES3
Aug 7, 2012 2:59 PM
Greetings All,
Is anyone using <XFAConversionSettings renderAtClient="true" /> in assembler DDX commands in ES3?
I have been using this setting to create Dynamic PDFs from XDP templates for years.
After migrating to an ES3 box, the asssembly fails trying to digest that option.
The only work-around I have is to set the default server option for forms generation to 'Client' via the AdminUI.
This works, but is not a long-term solution.
Has anyone encountered this, or know what adjustment I might need to make?
<?xml version="1.0" encoding="UTF-8"?>
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
<PDF result="docAssembledPDF">
  <XDP>
    <XDP retainInsertionPoints="All" source="docBase"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc2"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc4"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc6"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc8"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc10"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc12"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc14"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc16"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc18"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc20"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc22"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc24"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc26"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc28"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc30"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc32"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc34"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc36"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc38"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc40"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc42"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc44"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc46"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc48"/>
    <XDPContent insertionPoint="SourceDocContent" source="doc50"/>
    </XDP>
  <XFAConversionSettings renderAtClient="true"/>
  </PDF>
</DDX>
[8/6/12 15:44:35:625 CDT] 00000055 WSRdbManagedC W   DSRA1300E: Feature is not implemented: javax.sql.PooledConnection.addStatementEventListener
[8/6/12 15:44:35:906 CDT] 0000004b SystemOut     O usageRightsResult is NULL
[8/6/12 15:44:36:015 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:36:031 CDT] 0000004b Executive     A   DDXM_N00000: Started processing result named output
[8/6/12 15:44:36:046 CDT] 0000004b Executive     A   DDXM_N00001: Successful assembly of result named output
[8/6/12 15:44:36:046 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:36:343 CDT] 0000004b SystemOut     O usageRightsResult is NULL
[8/6/12 15:44:36:484 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:36:500 CDT] 0000004b Executive     A   DDXM_N00000: Started processing result named output
[8/6/12 15:44:36:562 CDT] 0000004b Executive     A   DDXM_N00001: Successful assembly of result named output
[8/6/12 15:44:36:562 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:36:843 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:36:843 CDT] 0000004b Executive     A   DDXM_N00000: Started processing result named output
[8/6/12 15:44:36:875 CDT] 0000004b Executive     A   DDXM_N00001: Successful assembly of result named output
[8/6/12 15:44:36:875 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:37:390 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:37:406 CDT] 0000004b Executive     A   DDXM_N00000: Started processing result named output
[8/6/12 15:44:37:421 CDT] 0000004b Executive     A   DDXM_N00001: Successful assembly of result named output
[8/6/12 15:44:37:421 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:37:968 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:37:984 CDT] 0000004b Executive     A   DDXM_N00000: Started processing result named output
[8/6/12 15:44:38:062 CDT] 0000004b Executive     A   DDXM_N00001: Successful assembly of result named output
[8/6/12 15:44:38:062 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:38:890 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() begin on thread WebContainer : 3 228
[8/6/12 15:44:38:890 CDT] 0000004b XDPSource     W   DDXM_W24003: Only one of the removeInsertionPoints or the retainInsertionPoints attributes may be specified; retainInsertionPoints will be ignored.
[8/6/12 15:44:38:906 CDT] 0000004b AssemblerServ E   ALC-ASM-S00-002: Failed to execute the DDX - error messages provided.
[8/6/12 15:44:38:906 CDT] 0000004b AssemblerServ E   TRAS0014I: The following exception was logged java.lang.RuntimeException: java.lang.NullPointerException
                at com.adobe.internal.ddxm.ddx.XFAConversionSettings.prepare(XFAConversi onSettings.java:72)
                at com.adobe.internal.ddxm.ddx.Node.prepare(Node.java:311)
                at com.adobe.internal.ddxm.ddx.DDX.prepare(DDX.java:232)
                at com.adobe.internal.ddxm.Executive.execute(Executive.java:215)
                at com.adobe.livecycle.assembler.AssemblerServiceImpl.execute(AssemblerS erviceImpl.java:520)
                at com.adobe.livecycle.assembler.AssemblerServiceImpl.invokeDDX(Assemble rServiceImpl.java:369)
                at sun.reflect.GeneratedMethodAccessor167.invoke(Unknown Source)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces sorImpl.java:37)
                at java.lang.reflect.Method.invoke(Method.java:611)
                at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(Defaul tPOJOInvokerImpl.java:118)
                at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(In vocationInterceptor.java:140)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.procee d(RequestInterceptorChainImpl.java:60)
                at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.int ercept(DocumentPassivationInterceptor.java:53)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.do InTransaction(TransactionInterceptor.java:74)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.execute(EjbTransactionCMTAdapterBean.java:357)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doSupports(EjbTransactionCMTAdapterBean.java:222)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTr ansactionCMTAdapter_caf58c4f.doSupports(Unknown Source)
                at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:104)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.inte rcept(TransactionInterceptor.java:72)
                at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.inte rcept(InvocationStrategyInterceptor.java:55)
                at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept( InvalidStateInterceptor.java:37)
                at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept (AuthorizationInterceptor.java:188)
                at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterc eptor.java:48)
                at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineI mpl.java:121)
                at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMes sage(AbstractMessageReceiver.java:93)
                at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessa geDispatcher.java:225)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(A bstractMessageDispatcher.java:66)
                at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:1 67)
                at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:893)
                at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke (WorkflowDSCInvoker.java:350)
                at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(Workflow DSCInvoker.java:158)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapt erBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:292)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTr ansactionCMTAdapter_caf58c4f.doRequiresNew(Unknown Source)
                at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute (EjbTransactionProvider.java:143)
                at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(A bstractMessageReceiver.java:329)
                at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeC all(SoapSdkEndpoint.java:139)
                at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke( SoapSdkEndpoint.java:81)
                at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source)
                at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.j ava:397)
                at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider .java:186)
                at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java: 323)
                at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrateg y.java:32)
                at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
                at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
                at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454 )
                at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
                at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:69 9)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:738)
                at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBas e.java:327)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:831)
                at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper .java:1607)
                at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper .java:1597)
                at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilte rChain.java:131)
                at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(I nvocationFilter.java:43)
                at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter(FilterI nstanceWrapper.java:184)
                at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(WebAppFilte rChain.java:116)
                at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:86)
                at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(WebAppFilt erChain.java:77)
                at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(WebAppFil terManager.java:908)
                at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletW rapper.java:934)
                at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletW rapper.java:502)
                at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(Serv letWrapperImpl.java:179)
                at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(Cac heServletWrapper.java:91)
                at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java: 864)
                at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.j ava:1592)
                at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.jav a:186)
                at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimina tion(HttpInboundLink.java:452)
                at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest (HttpInboundLink.java:511)
                at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(H ttpInboundLink.java:305)
                at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(Htt pICLReadCallback.java:83)
                at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted (AioReadCompletionListener.java:165)
                at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFutu re.java:217)
                at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChanne lFuture.java:161)
                at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
                at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
                at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.j ava:775)
                at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
                at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1604)
Caused by: java.lang.NullPointerException
                at com.adobe.internal.ddxm.ddx.XFAConversionSettings.prepare(XFAConversi onSettings.java:69)
                ... 134 more
[8/6/12 15:44:38:906 CDT] 0000004b AssemblerServ A   ALC-ASM-N00-001: Execute: invokeDDX() end on thread WebContainer : 3 228
[8/6/12 15:44:39:343 CDT] 0000004b WorkManagerFa I   ASYN0067I: Resource ard is being looked up without using resource reference.
[8/6/12 15:44:39:343 CDT] 0000004b WorkManagerFa I   ASYN0067I: Resource default is being looked up without using resource reference.
[8/6/12 15:44:39:343 CDT] 0000004b SystemOut     O ASYN0069E: TimerManager default is being looked up without using resource reference.
[8/6/12 15:44:39:343 CDT] 0000004b TimerManagerF E   ASYN0069E: TimerManager default is being looked up without using resource reference.
[8/6/12 15:44:39:390 CDT] 0000004b WorkManagerFa I   ASYN0067I: Resource ard is being looked up without using resource reference.
[8/6/12 15:44:39:390 CDT] 0000004b WorkManagerFa I   ASYN0067I: Resource default is being looked up without using resource reference.
[8/6/12 15:44:39:390 CDT] 0000004b SystemOut     O ASYN0069E: TimerManager default is being looked up without using resource reference.
[8/6/12 15:44:39:390 CDT] 0000004b TimerManagerF E   ASYN0069E: TimerManager default is being looked up without using resource reference.
