bmcfiv
Acrobat X - Print to Edge without Margin
Aug 8, 2012 9:50 AM
Tags: #acrobat #edge #print #margin
Using Acrobat X Standard and Microsoft PowerPoint, I'm trying to print a pdf where there isn't any margin (also for Word docs).  I've tried "Scale to Fit Paper" but that leaves a slight margin on the top and bottom.  I'm basically trying to print so that it looks exactly like the pdf I've created so that when someone opens on their screen, it will not show any margins, just the content and background i've created.
Any suggestions?
Thank you!
    Aug 8, 2012 9:56 AM   in reply to bmcfiv
    Hi bmcfiv,
    I'm not sure I entirely understand your issue, but I may have a suggestion.
    I'm assuming that there are margins in the document you are working with that you are trying to get rid of. Is this correct? If so, you can use the Crop tool in the Tools panel. You would simply draw a rectangle excluding the margins, and hit enter.
    I hope this helps.
    Aug 9, 2012 9:09 AM   in reply to bmcfiv
    Are you using the PDFMaker Add-in in PowerPoint to create your PDF or a different technique? If not, try using this first.
    Aug 9, 2012 12:24 PM   in reply to bmcfiv
    Don't forget you can crop all pages at once.
    Aug 24, 2012 8:04 AM   in reply to bmcfiv
    Thanks for letting us know.
