I am trying to use InDesign using Java via ORB.
When I run following java program
package indesigntest;
import java.io.BufferedReader;
import java.io.FileReader;
import org.omg.CORBA.ORB;
import org.omg.CORBA.Object;
import com.adobe.ids.IdsException;
import com.adobe.ids.basics.Application;
import com.adobe.ids.basics.ApplicationHelper;
public class Main {
public static void main(String[] args) {
try {
ORB orb = ORB.init(args, null);
BufferedReader iorIn = new BufferedReader(new FileReader("d:\\ior.txt"));
String application_IOR = iorIn.readLine();
Object object = orb.string_to_object(application_IOR);
Application myApp = ApplicationHelper.narrow(object);
myApp.consoleerr("Error occur");
myApp.consoleout("First Hello Server");
} catch (IdsException e) {
e.printStackTrace();
} catch (Exception e) {
I got following exception:
com.adobe.ids.IdsException: IDL:com/adobe/ids/IdsException:1.0
at com.adobe.ids.IdsExceptionHelper.read(Unknown Source)
at com.adobe.ids.basics._ApplicationStub.consoleerr(Unknown Source)
at indesigntest.Main.main(Main.java:18)
Here is InDesign server command that is running sucessfully at backend
D:\>c:
C:\>cd\
C:\>cd C:\Program Files\Adobe\Adobe InDesign CS6 Server x64
C:\Program Files\Adobe\Adobe InDesign CS6 Server x64>InDesignServer -iorfile d:\
ior.txt -pluginpath Server\Corba
. InDesign CS6 Server Version 8.0 x64 Evaluation
. Copyright 1999-2012 Adobe Systems Incorporated and its licensors.
. All rights reserved. See the other legal notices in the ReadMe.
08/09/12 17:41:07 INFO [server] Initializing
08/09/12 17:41:07 INFO [server] Loading the application
08/09/12 17:41:07 INFO [server] Restoring Object Model
08/09/12 17:41:07 INFO [server] Scanning for plug-ins
08/09/12 17:41:08 INFO [server] Initializing plug-ins
08/09/12 17:41:08 INFO [server] Starting up Service Registry
08/09/12 17:41:25 INFO [server] Executing startup services
08/09/12 17:41:25 INFO [server] Using configuration configuration_noport
08/09/12 17:41:28 INFO [server] Initializing Application
08/09/12 17:41:28 INFO [server] Completing Initialization
08/09/12 17:41:32 INFO [server] Image previews are off
08/09/12 17:41:32 INFO [server] Server Running
08/09/12 17:41:32 INFO [javascript] Executing File: C:\Program Files\Adobe\Adob
e InDesign CS6 Server x64\Scripts\startup scripts\ConnectInstancesToESTK.js
e InDesign CS6 Server x64\Scripts\converturltohyperlink\startup scripts\ConvertU
RLToHyperlinkMenuItemLoader.jsx
e InDesign CS6 Server x64\Scripts\converturltohyperlink\ConvertURLToHyperlinkMen
uItem.jsxbin
08/09/12 17:41:36 INFO [server] Initializing Corba API
08/09/12 17:41:36 INFO [server] ApplicationIOR:010000002200000049444c3a636f6d2f
61646f62652f6964732f4170706c69636174696f6e3a312e3000000001000000000000 0068000000
010102000b00000031302e302e302e3231390000380a000013000000ff6964735f706f 61fe00b023
50010008b40031000200000000000000080000000100000000545441010000001c0000 0001000000
010001000100000001000105090101000100000009010100
08/09/12 17:41:36 INFO [server] Writing IOR to 'd:\ior.txt'
Generated iot.txt file
IOR:010000002200000049444c3a636f6d2f61646f62652f6964732f4170706c696361 74696f6e3a312e30000000010000000000000068000000010102000b00000031302e30 2e302e3231390000d008000013000000ff6964735f706f61fe8fa023500100130c0031 000200000000000000080000000100000000545441010000001c000000010000000100 01000100000001000105090101000100000009010100
Environment:
Windows 7 64 bit
JDK 6
Adobe InDesign CS5.5 Server SDK
Trial Activated using
"adobe_prtk --tool=StartTrial --leid=InDesignServer-CS6-Win-GM"
PLEASE LET ME KNOW WHAT I AM MISSING.
I am also interested in Indesign purchase if it got working.
Thanks in advance.
Hey,
unfortunately Adobe has stopped supporting their Java-API.
Read here:
http://forums.adobe.com/thread/997395?tstart=0
Nils
North America
Asia Pacific
