Virussia
Need help in Adobe Photoshop CS6 Extended
Aug 10, 2012 12:54 PM
Tags: #update #windows #wikipedia
How can I make a dialog window with transparent background which looks like exactly like this:
http://upload.wikimedia.org/wikipedia/en/b/b0/Windows_Update.png
With transparent background, so the Aero glass color is white.
http://en.wikipedia.org/wiki/File:Windows_Update.png
If you hover your mouse over the picture, you may see checkered patterns, which is transparent, so the Aero glass can see through the checkered patterns. (Note: Please do this in the link above.)
How can I do this like the Aero glass see through the checkered patterns above?
  • JJMack
    Jan 9, 2006
    Aug 10, 2012 8:57 PM   in reply to Virussia
    What is there is a image file format png not a dialog window.  What application will use the dialog what tools do you have? Adobe Flash which I don't have or use may be able to do that type dialog. In Photoshop scripting folder sub folder \Sample Scripts\ javascript there is a script that uses Adobe Flash for its UI files:
    FlashUISample.jsxl
    FlashUISample.mxml
    FlashUISample.swfs
    Also the frames on normal Photoshop scripts dialogs written in javascript seem to be semi transparent
    Aug 12, 2012 10:28 AM   in reply to Virussia
    You want to know how to draw a dialog box that has aero effects or know how to make script windows (dialogs) look like that?
  • Noel Carboni
    Dec 23, 2006
    Aug 12, 2012 10:59 AM   in reply to Virussia
    You will want to use one or more Layers, partial layer transparency (e.g., by using a grayscale Layer Mask), and save in a format that can carry transparency such as PNG.
    Note that you will never be able to achieve the blurring that Aero Glass does to things that show through, so the effect will never match Windows very well.  With Windows 8 there will be no more transparency of individual windows, by the way - just partial transparency of the Taskbar.
    You can determine the extent of the transparency and the color used, in order to learn to match it, by loading the very PNG you put up in your post above into Photoshop (CS5 or newer), then do Layer - Layer Mask - From Transparency.
    -Noel
    Aug 12, 2012 11:06 AM   in reply to Virussia
    Something like this: (you might have to experiment with using different colors)
    http://www.youtube.com/watch?v=JJZMFvxpnNg
    http://www.youtube.com/watch?v=10_SfXO5Kzc
  • Noel Carboni
    Dec 23, 2006
    Aug 12, 2012 11:56 AM   in reply to Noel Carboni
    You could make a background gradient very similar to theirs, based on what you can see up at the top of the window, and replace the entire content of the window with that.  Then you could put whatever client area you want on top of that.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 12, 2012 12:09 PM   in reply to Virussia
    What is your intent?  To create a Photoshop design that uses partially transparent layers?  To display partially transparent things in a web browser?  If so, I have already told you exactly what you want to do.
    You're going to need to go research how layers and transparency work in Photoshop I think.  That's a bit beyond a Q & A forum to teach.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 12, 2012 12:29 PM   in reply to Virussia
    Layer - New Layer, Color: X None.  That creates a new completely transparent layer on which you can paint things.
    Select something with pixels in it, Edit - Copy, then Edit - Paste over whatever layers are there.  That will create a new layer with transparency all around the pixels you copied and pasted.
    To make a layer mask with which to make parts of a layer transparent, Layer - Layer Mask - Reveal All, then paint black on the Layer Mask.  Gray makes it partially transparent.
    -Noel
