Hello,
I have a flash game with several videos. I am using netstream to play my videos. the project is in actionscript 2.0. Is there a way to adjust the volume of the videos individually? Most of my videos have correct volume, but some are too quiet.
Mark.
Thank you for your help. I have tried to put your script in what I have and I am doing something wrong. I put the code in every spot that I thought would work and changed the "your.ns" to "new NetConnection()", "new NetStream(nc)" and "aud1." None have worked. Below is the code that plays my video and reacts to cue points.
var nc:NetConnection = new NetConnection();
nc.connect(null);
var ns:NetStream = new NetStream(nc);
aud1.attachVideo(ns);
ns.play("http://www.mysite.org/video/myvideo/1.flv");
ns.onCuePoint = function(evt:Object){
trace(evt.name);
trace(evt.time);
if(evt.name == "c1") {
trace("YO !Jump to 108!");
gotoAndPlay(108);
Thanks again for your help.
Mark.
I had started another post, I appologize if this caused any inconvenience. The last posting gave a solution, but it did not work. the error message I get is,
Under Location:
Scene+Scene 1, layer=vid action, frame=114. line 4
Under Description:
The class or interface 'SoundTransform' could not be loaded.
Under Source
var st:SoundTransform=ns.soundTransform;
The code I loaded in the actions frame:
nc.connect(null);
st.volume=0.5;
ns.soundTransform=st;
ns.play("www.mysite.org/video/1.flv");
trace(evt.name);
trace(evt.time);
gotoAndPlay(108);
This was the suggestion of the last post.
Thank you again for your help.
Mark.
I believe that soundTransform is AS3, while the rest of your project is AS2... so that won't work.
You can use this method instead:
//-------Sound Controls--------//
this.createEmptyMovieClip("sound_mc",this.getNextHighestDepth());
sound_mc.attachAudio(ns);var videoSound:Sound = new Sound(sound_mc);
videoSound.setVolume(100);
Use volume of 100 as starting point. For turn up volume on very quiet videos, set volume to 400 or so. To turn volume down, use a volume less than 100.
Add this code in after the very last
of the code you posted... The audio control code does not go inside ns play function.
Best wishes,
Adninjastrator
North America
Asia Pacific
