How to create the backside of an image in Flash cs6?
Aug 11, 2012 12:34 PM
Tags: #image #transform #free #action_script_3 #flash_cs6 #envolope
I am using flash cs6, and I use the envolope mode with the free transform to warp an image. I am trying to create a page turn effect. But the problem is, when I warp an image such that you can see behind an image, currently the back side is transparent, and I see the layer behind the current layer.
In photoshop, i know when you warp an image to see behind it, whats behind it is the mirrored version of the image (or rather horizontally flipped).
Like that can I define the back of an image or layer in flash to be a certain color or another image?
  • kglad
    Jul 21, 2002
    Aug 12, 2012 10:19 AM   in reply to omega123456
    the transform tool and code work the same in flash.  if you're not seeing the anything it's because your transformed image has been moved (translated).
  • kglad
    Jul 21, 2002
    Aug 12, 2012 12:21 PM   in reply to omega123456
    again, your transformed object is translated (and probably rotated).  to see where it's located disable the mask you're using for the transformed object.
