MadsKlitgaard
Help with table column strokes
Aug 13, 2012 4:04 AM
Tags: #table #stroke #cell
I'm in the middle of creating a price list and we've been brainstorming some pricelist ideas.
We've finally come up with one we want to use, but I simply cannot get the table strokes to do what i want them to do.
I've attached an image of how we want the table to look.
As you can see the column strokes are not full length of the cell, but how do I format the table function to do this?
    Aug 13, 2012 4:44 AM   in reply to MadsKlitgaard
    You'll to put a "buffer" row between each row.
    Then select that row between the rows and choose Split Cell Horizontally - (to keep the automatic fill)
    It's not automatic and I imagine very tedious.
    Let me think about this a bit more
    Aug 13, 2012 4:49 AM   in reply to Eugene Tyson
    Or for the text you could apply a Rule Above and change the indents to suit
    This would be more automatic - it will allow you to retain automatic fills, and you can apply these directly with a paragraph style.
    You can also apply the row stroke to each separate row in the styles - if you're using styles
    Aug 13, 2012 8:47 AM   in reply to Eugene Tyson
    @Eugene – I'd rather use the "Bullets and Numbering" feature of a paragraph style. You can add the character  "|" (Vertical Line) as custom bullet and formatting that with  a character style where you scale vertical to about 150% and fill color "[Paper]" and a little baseline shift if you like.
    If you are using "Rule Above" for paragraph styles, you cannot easily change column widths of the table without adjusting "Right Indent" values…
    Uwe
    Aug 16, 2012 3:06 AM   in reply to Eugene Tyson
    @Eugene – I have to correct myself: it is quite possible to use "Rule Above" without defining a specific value for "Right Indent". We could leave that  value to "0", if we define a custom stroke style and use that instead of the predefined "normal" one.
    See the following screen grab from the German forum "HilfDirSelbst". The suggestion is made by Kai Rübsamen. A very clever solution to a similar problem that can easily be applied in MadsKlitgaard's situation:
    http://www.hilfdirselbst.ch/gforum/gforum.cgi?do=post_attachment;posta tt_id=6418;
    The length of the pattern could be the page width or larger, so it would not repeat itself by any chance, if the cell widths vary.
    Length (Länge): 0.5 pt (line width)
    Pattern Length (Länge des Musters): 300 mm
    Corners (Ecken): None
    Uwe
    Aug 16, 2012 3:34 AM   in reply to Laubender
    (Uwe, that part of the forum requires registration. Here is a copy of the image:
    Aug 16, 2012 5:10 AM   in reply to [Jongware]
    @Jongware – thank's for helping out. I wasn't aware of this 'cause I'm always logged in…
    Uwe
