arnonshorr Calculating status...
These don't appear to be serious, but several programs (notably photoshop, illustrator) installed with similar errors.
1) are these a big deal/something to worry about?
2) what can I do to fix these types of errors?
a full listing of the errors from one recent installation:
Exit Code: 6 Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF012, DF024 ... WARNING: DF054, DW016 ... -------------------------------------- Summary -------------------------------------- - 0 fatal error(s), 35 error(s), 9 warning(s) WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 WARNING: DW016: NOTE: Cannot set action to the payload {B8ADDCBD-30D9-4366-AE25-089CEF76C8E1} Suite Shared Configuration CS6 3.0.0.0 as it is already upgraded by the payload {8706963D-5F48-47CC-998B-DAB70B089DB8} Suite Shared Configuration CS6 3.0.0.0 ----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 ----------- WARNING: DF054: Unable to read Adobe file version for file path 'C:\Program Files (x86)\Common Files\Adobe\Color\Profiles\Recommended\USSheetfedCoated.icc'(Seq 14) ERROR: DF012: Unable to find file(Seq 14) ERROR: DF024: Unable to preserve original file at "C:\Program Files (x86)\Common Files\Adobe\Color\Profiles\Recommended\USSheetfedCoated.icc" Error 32 The process cannot access the file because it is being used by another process.(Seq 14) ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 14) ERROR: DW050: The following payload errors were found during install: ERROR: DW050: - Adobe Bridge CS6 (64 Bit): Install failed ERROR: DW050: - AdobeColorCommonSetCMYK CS6: Install failed ERROR: DW050: - AdobeColorJA CS6: Install failed ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS6 x64: Install failed ERROR: DW050: - Required Common Fonts Installation: Install failed ERROR: DW050: - Adobe CSXS Infrastructure CS6: Install failed ERROR: DW050: - AdobeColorEU CS6: Install failed ERROR: DW050: - Required Common Fonts Installation x64: Install failed ERROR: DW050: - AdobeIdeaPluginCS6 x64: Install failed ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS6: Install failed ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS6 x64: Install failed ERROR: DW050: - Adobe Illustrator CS6 Core: Failed due to Language Pack installation failure ERROR: DW050: - PDF Settings CS6: Install failed ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed ERROR: DW050: - Adobe Extension Manager CS6: Install failed ERROR: DW050: - Adobe NPS Panel: Install failed ERROR: DW050: - Adobe Illustrator CS6 Core_AdobeIllustrator16en_USLanguagePack: Install failed ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS6: Install failed ERROR: DW050: - Adobe Bridge CS6: Install failed ERROR: DW050: - Adobe Illustrator CS6 Core (64 Bit)_AdobeIllustrator16en_USLanguagePack_x64: Install failed ERROR: DW050: - Adobe Illustrator CS6 Core (64 Bit): Failed due to Language Pack installation failure ERROR: DW050: - AdobeIdeaPluginCS6: Install failed ERROR: DW050: - AdobeColorNA CS6: Install failed ERROR: DW050: - Adobe Linguistics CS6 x64: Install failed ERROR: DW050: - AdobeColorCommonSetRGB CS6: Install failed ERROR: DW050: - Adobe Illustrator CS6 Support32: Install failed ERROR: DW050: - AdobeHelp: Install failed ERROR: DW050: - Adobe Linguistics CS6: Install failed ERROR: DW050: - Recommended Common Fonts Installation: Install failed ERROR: DW050: - Adobe CSXS Extensions CS6: Install failed ERROR: DW050: - Adobe ExtendScript Toolkit CS6: Install failed ERROR: DW050: - Adobe Illustrator CS6 Support: Install failed -------------------------------------------------------------------------------------
1 Reply
Latest reply:
David__B, Aug 14, 2012 5:35 PM
