• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
How do I create a transparent stroke above other shapes?
Guest
Aug 14, 2012 Aug 14, 2012
Hello
I have the following shape:
What I'm trying to do is give the blue box a transparent stroke that will "cut through" the red boxes and show the background underneath, whatever that may be ...white, another color, or a photo.
I can easily achieve this when I give it a white stroke. It'll look like this:
When I change to a background color other than white or even a photo however, I end up with this problem:
How do I make it so that I have a transparent border (not white) around the blue box? Which effectively cuts a "transparent stroke" (space) between the parts where the blue and red boxes intersect?
Thank you very much for any advice I've been trying to get this done for days without success, so you're my last hope!
Views
56.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 15, 2012 Aug 15, 2012
1. Select the blue rectangle with the white stroke, then do as Silkrooster suggests to set the stroke's opacity to 0. The white stroke will disappear.
2. Select all three rectangles and group them.
3. With the group selected, the Appearance panel should show:
    Group
    Contents
    Opacity
Click on Opacity. In the box that opens, click the box next to Knockout Group until the check/tick mark appears. If the dash appears, click again.
Votes
Translate
Translate
Adobe
LEGEND ,
Window>Appearence or shift-F6. Once the appearence panel is open, Twirl down the icon next to the word Stroke, Click Opacity and adjust it to your hearts desire...
Votes
Translate
Translate
Report
Report
Community Expert ,
    Group
    Contents
    Opacity
Votes
Translate
Translate
Report
Report
Guest
Thank you SO much you both, that worked perfectly
Votes
Translate
Translate
Report
Report
Community Expert ,
You're welcome.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 18, 2013 Apr 18, 2013
I have been trying to figure this out for so long! thank you Although I have one problem, when i import the file as an eps into my indesign document the whote lines appear again. Help! 😕
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 19, 2013 Apr 19, 2013
Don't use EPS. This file format doesn't support transparency. You will have to use AI (with PDF content enabled) or PDF to get the transparency into ID.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 18, 2023 Oct 18, 2023
I am trying this with text (one word on the bottom layer and then a few words of text in a different font over top)...I am trying to "knockout" a stroke around the top text so that it cuts as a transparent stroke into the bottom layer of text. I tried doing it before creating outlines of the text and then again with creating outlines, but it doesn't seem to be working either way. (I'm not able to lower the opacity of just the stroke, and after creating outlines opacity does not come up as an option in Appearance). I acheived the look I want in Photoshop, but whenever I'm trying to save this as an EPS (for a t-shirt design), it is making it a flat jpg. Any help appreciated!
Votes
Translate
Translate
Report
Report
Community Expert ,
Do not apply the stroke to the characters. Instead select the text object with the selection tool (just one click). Then add a stroke using the appearance panel. And then you can set the opacity of that stroke to 0%.
Votes
Translate
Translate
Report
Report
Thank you so much! I was able to get the effect to work. The only issue is that the stroke is not coming out very clean...I tried lowering the stroke, but still having the same tearing. Any thoughts?
Votes
Translate
Translate
Report
Report
Community Expert ,
The simple fix would be to set the corners of the stroke to rounded. If you do not want that, you will look into outlining the font and adjusting the path.
Votes
Translate
Translate
Report
Report
That helped! Thanks so much!
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
You're welcome!
Votes
Translate
Translate
Report
Report
