PHDS, encryption weirdness?
Aug 15, 2012 8:34 AM
Tags: #4.5 #fmis #phds #4.5.2
in an earlier post of mine (http://forums.adobe.com/message/4364896) it was stated that the content encryption key was derived from the common-key and the Content ID.
Now, I've been experimenting some with this, inserting a proxy doing some filename translations between the client and the actual server, any requests containing "999x222Seg*" gets rewritten to "999y222Seg*", i.e. a different filename. Both "999x222.mp4" and "999y222.mp4" exists on the server.
Client requests /hds-vod/999x222.mp4.f4m, proxy forwards exactly the same. Server sees 999x222_1400.mp4.f4m as filename, and the drmAdditionalHeader is set to drmContentId="999x222.mp4" as expected
Now, the client requests /hds-vod/999x222.mp4Seg1-Frag1 as expected. This is however translated in the proxy, and the server will see a request for /hds-vod/999y222.mp4Seg1-Frag1, i.e. NOT the same filename as the manifest was issued for, and thus not the same content ID (?), which would mean another content encryption key would be used.. However, the client is still able to play the video!
From my understanding, that should not be possible? 999x222.mp4 and 999y222.mp4 are two different files, two different content IDs, and should thus have two different content encryption keys. The key from the initial manifest should only be able to decrypt the fragments from 999x222, not 999y222?
FMIS 4.5.2 is used, and the default /hds-vod PHDS config is used, with protection specifics as follows:
EncryptionScope server
ProtectionScheme phds
PHDSCommonKeyFile ../phds/common-key.bin
PHDSPlaybackExpiration "24Hours"
PHDSOutputProtection None
PHDSVideoEncryptionLevel 2
Can anyone shed some light on this?
Thank you
    Aug 27, 2012 9:47 PM   in reply to j_1234
    Hi J_1234,
    Can you give us your httpd conf ?
    Thank you.
    Aug 31, 2012 12:11 AM   in reply to j_1234
    By default, FMS uses non-unique content-id if protection-scheme is set. It takes path of the file as its content-id. Therefore, in your case, it takes same content-id for both files as they are kept in same folder. This was introduced so that same content-id encryption can be used for multi-bitrate stream where all files with different bit rate are kept in same folder.
    If you want to use unique content-id for each file, please include this tag in ur httpd.conf file.
    FlashAccessUseUniqueContentID true
    By default, this is set as false.
    Also, If you want to specify some content-id (for example: 'my-content-id') to be used as content-id for all the files, please use this tag. Also, donot set FlashAccessUseUniqueContentID to true.
    setFlashAccessContentID my-content-id
