Taikey
Removing Movie Clip using RemoveChild Help
Aug 16, 2012 4:39 AM
Hi, im new to this forum, and new to actionscript 3.
I'm wondering, how can you remove the movieclip so that it doesnt stack when you click another button.
Btn 1 opens the movieclip by addchild
Btn 2 opens the 2nd movieclip but stacks in front , and the first movieclip isnt removed
AS linkage of my movieclip so that i can bring it to stage.
My code
thumbnail1.addEventListener(MouseEvent.CLICK ,myThumb1);
function myThumb1(evt:MouseEvent):void
var myMC:hover1 = new hover1();
container.addChild(myMC);
if(contains(myMC))
container.removeChild(myMC)
thumbnail2.addEventListener(MouseEvent.CLICK ,myThumb2);
function myThumb2(evt:MouseEvent):void
var myMC2:hover2 = new hover2();
container.addChild(myMC2);
    Aug 16, 2012 5:12 AM   in reply to Taikey
    By declaring the vars inside the function, you remove any ability to target them directly by name outside of the function.  So one way to deal with this would be to declare myMC1 and myMC2 outside of any functions so that every function can target them.
    An alternative approach would be to just empty the container out before adding any children to it using the removeChildAt() method (you need to check that there are children within it to remove beforehand)
    For the code you show, your myThumb1 function isn't going to do much for you since it is adding myMC1 and removing it immediately after that
    Aug 16, 2012 5:20 AM   in reply to Taikey
    Here is your code rewriten using the second approach I described...
         while(container.numChildren > 0){
             container.removeChildAt(0);
    Aug 16, 2012 6:26 AM   in reply to Taikey
    For the code you showed, I would guess you wanted to check if it contains the other other mc (myMC2), not the one you just added because the one you just added is definitely there.  Also, you probably want to specify it for the container since that is where you place the instances, as in...
    if(container.contains(myMC2))
    Aug 16, 2012 7:23 AM   in reply to Taikey
    I think I already provided the guidance you need, you just need to reread what I answered already and think it thru... if you are adding myMC1, which mc do you need to remove (not myMC1, right?)?
    If you are having trouble with your assignment I suggest you either work with one of your classmates or your instructor to help resolve your understanding.
