ALTERNITIVE LAYOUT LINKS
Aug 16, 2012 11:15 AM
I created a horizontal layout, then I generated an alternate layout (vertical)
Pages and content are linked properly.
I want to add a new set based on the same layout.
How can I duplicate a new set based off existing layout and have them linked properly?
    Aug 16, 2012 12:26 PM   in reply to SFS-DPS
    To SFS-DPS,
    "How can I duplicate a new set based off an existing layout and have them linked properly"?
    Did you duplicate the folio as these links would be the same as the new altered copy also all the settings from the master page. I dont think alternative layouts are fully supported at present maybe adding a single vertical orientation to your folio and then re connecting to the resources would work better.
    Regards
    Vividi
    Aug 17, 2012 8:35 AM   in reply to SFS-DPS
    I think you would need to manually reconnect any links or file resources,but you could also try using the new content collector tool to make the V and H alternate layouts and see if that works
    Regards
    Vividi
