If you're having problems with sequence presets and codecs missing from Premiere Pro, see this document for solutions for this activation issue.
This document relates to the following problems:
These failures are all because Premiere Pro and Encore use some codecs that require activation before they can be used. If activation of these codecs has failed, these codecs will not be available to use.
Have something to add?
