Seam in reflected objects
Aug 16, 2012 12:06 PM
I got some great help with reflected styles from this thread the other day. But now I'm getting some weird display issues. At most of the zoom levels, or when I export from Illustrator, or when I place these in Indesign (to add some text and export to share with my team) I see this seam ...
But when I zoom in a lot, my art looks fine, no seam...
I'm creating some icons that have to be 512x512, but most of the time they'll display at 100x100px, so it's important they look good at that size. Right now I get a seam at that size. Things I've tried:
  1. Grab all the end points and align center (relative to selection).
  2. Ensure that none of those end points have handles at an angle other than flat horizontal.
What has worked:
  • Exporting all artboards at a very large resolution, importing into photoshop, convert to smart object, and resize, realign, etc. and export that image to share with others. Pain in the neck to alter my design and reshare with team.
What has not worked:
  • Place the illustrator artboards in InDesign (preferred) – still see a seam
  • Export as pngs and place in InDesign (not preferred) – no seam, but bad image quality
How I would like this to work:
Shouldn't I be able to have no seam at any zoom level and export without a seam? Is there a trick I'm missing? Cheers.
    Aug 16, 2012 12:31 PM   in reply to Petros_
    If you go into Preferences and turn off Anti-aliasing, do the seams go away? If so, then you should be alright.
    Aug 16, 2012 12:58 PM   in reply to Petros_
    As it should. You're just checking to see if the seams are simply screen artifacts.
    Aug 20, 2012 2:21 AM   in reply to Petros_
    Of there are cures. But not for the live object.
    If you expand it and then unite the shapes, seams are gone.
    If you print the art (offset printing), seams will in 99% of cases be gone as well.
