CNKratos
A problem of Channel disconnected(Flex & PHP)
Aug 16, 2012 8:26 PM
Tags: #error #php #flex4.6 #database_connecting
Hi there,
I am also a rookie of Flex. Recently,I try to learn it with the Adobe’s tutorials which locals on:
http://www.adobe.com/cn/devnet/flex/testdrive/articles/2_modify_the_da tabase.html#links
However,when I attempt to add some employees as the tutorial
says,there always be an error:
Channel disconnected before an acknowledgement was received
Even though I searched for the solution a lot times,I haven’t find a appropriate one.
It bothers me several days
So, if you guys knew how to figure it out , please do me a favor.
Thanx a lot
Nick
    Jan 1, 2013 8:08 AM   in reply to CNKratos
    SOLUTION:
    When you follow the TestDrive tutorial you assume that all the syntax is 100% OK. That is not the case here.
    If you try to use the functions createEmployee(), updateEmployee() or deleteEmployee() you will notice that it needs to bind the parameters to the $stmt variable. When the PHP service (in this case:  EmployeeService) is called and the function reaches the point where the binding is performed the PHP will return a PHP Fatal error (you may check on your PHP log - usualy in C:\xampp\php\logs\php_error_log)  informing that there is a Call to undefined function mysqli_bind_param().
    To solve this you must  change your code as described below:
          Let's assume we are working with the function createEmployee()
      public function createEmployee($item) {
         $stmt = mysqli_prepare($this->connection,
         "INSERT INTO employees (
         firstname,lastname,title,departmentid,officephone,cellphone,
         email,street,city,state,zipcode,office,photofile)
         VALUES (?, ?, ?, ?, ?, ?,?,?,?,?,?,?,?)");
         $this->throwExceptionOnError();
    all the same until now... BUT, notice the very beggining of the next statement...
              $stmt->bind_param('sssisssssssss', $item->firstname, $item->lastname,
                        $item->title, $item->departmentid, $item->officephone, $item->cellphone,
                        $item->email, $item->street, $item->city, $item->state,
                        $item->zipcode, $item->office, $item->photofile);
    When you check the original code you will notice that the
           mysqli_bind_param($stmt,
    was replaced by
           $stmt->bind_param(.
    This will solve the problem for good
    Best regards!
    Pitagoras
    Jan 6, 2013 7:54 AM   in reply to Vixborn
    The issue is because mysqli_bind_param() function has been DEPRECATED as of PHP 5.3.0 and REMOVED as of PHP 5.4.0.
    Source: http://php.net/manual/en/function.mysqli-bind-param.php
    Replacing that with mysqli_stmt_bind_param() works .
    Cheers,
    raghu
    Feb 19, 2013 6:15 AM   in reply to Vixborn
    Amazingly helpful! Thank god people like you exist because you just helped me massively!
