I've been messing around with building out a script that will allow users to replace content in a text layer.
Unfortunately, the content is going to always be different, formatted differently, and not placed in any sort of XL or CSV file.
I'd like to be able to run a script that will select the appropriate named text layers and then prompt the user to input the various values. The only script I've been able to find along those lines is on the ps-scripts site here:
prompt the user for textual input - Script
Anyone come up or across something that falls within those interaction parameters?
Thanks!
Something like this? ...
#target Photoshop
app.bringToFront();
main();
function main(){
if(!documents.length) return;
var txtArray = new Array();
txtArray = getTxtInfo();
var win = new Window( 'dialog', '' );
g = win.graphics;
var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]);
g.backgroundColor = myBrush;
win.orientation='stack';
win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
win.g1 = win.p1.add('group');
win.g1.orientation = "row";
win.title = win.g1.add('statictext',undefined,'Text Replacement');
win.title.alignment="fill";
var g = win.title.graphics;
g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
win.g5 =win.p1.add('group');
win.g5.orientation = "row";
win.g5.alignment='left';
win.g5.spacing=10;
win.g5.st1 = win.g5.add('statictext',undefined,'Layer Name');
win.g5.st1.preferredSize=[110,20];
win.g5.dd1 = win.g5.add('dropdownlist');
win.g5.dd1.preferredSize=[300,20];
win.g10 =win.p1.add('group');
win.g10.orientation = "row";
win.g10.alignment='left';
win.g10.st1 = win.g10.add('statictext',undefined,'Layer Contents');
win.g10.st1.preferredSize=[110,20];
win.g10.et1 = win.g10.add('edittext',undefined,'');
win.g10.et1.preferredSize=[300,20];
win.g10.et1.enabled=false;
for(var a in txtArray){
win.g5.dd1.add('item',txtArray[a][1].toString());
win.g5.dd1.selection=0;
win.g10.et1.text=txtArray[0][2].toString();
win.g5.dd1.onChange=function(){
win.g10.et1.text=txtArray[this.selection.index][2].toString();
win.g15 =win.p1.add('group');
win.g15.orientation = "row";
win.g15.alignment='fill';
win.g15.st1 = win.g15.add('statictext',undefined,'Replace text with:- ');
win.g15.st1.preferredSize[150,20];
win.g15.et1 = win.g15.add('edittext',undefined,'');
win.g15.et1.preferredSize=[350,20];
win.g20 =win.p1.add('group');
win.g20.orientation = "row";
win.g20.alignChildren='fill';
win.g20.bu1 = win.g20.add('button',undefined,'Update Text');
win.g20.bu1.preferredSize=[200,35];
win.g20.bu2 = win.g20.add('button',undefined,'Cancel');
win.g20.bu2.preferredSize=[200,35];
win.g20.bu1.onClick=function(){
if(win.g15.et1.text == ''){
alert("No replacement text has been entered!");
return;
win.close(0);
selectLayerById(Number(txtArray[win.g5.dd1.selection.index][0]));
activeDocument.activeLayer.textItem.contents=win.g15.et1.text;
win.center();
win.show();
function getTxtInfo(){
var ref = new ActionReference();
ref.putEnumerated( charIDToTypeID('Dcmn'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
var count = executeActionGet(ref).getInteger(charIDToTypeID('NmbL')) +1;
var Names=[];
try{
activeDocument.backgroundLayer;
var i = 0; }catch(e){ var i = 1; };
for(i;i<count;i++){
if(i == 0) continue;
ref.putIndex( charIDToTypeID( 'Lyr ' ), i );
var desc = executeActionGet(ref);
var layerName = desc.getString(charIDToTypeID( 'Nm ' ));
var Id = desc.getInteger(stringIDToTypeID( 'layerID' ));
if(layerName.match(/^<\/Layer group/) ) continue;
var layerType = typeIDToStringID(desc.getEnumerationValue( stringIDToTypeID( 'layerSection' )));
var Vis = desc.getBoolean(stringIDToTypeID( 'visible' ));
if( desc.hasKey( stringIDToTypeID( 'textKey' ) )) {
var contents = desc.getObjectValue(stringIDToTypeID('textKey')).getString( stringIDToTypeID('textKey'));
if(!Vis) continue; //do not select hidden layers
Names.push([[Id],[layerName],[contents]]);
return Names;
function selectLayerById(ID, add) {
add = (add == undefined) ? add = false : add;
ref.putIdentifier(charIDToTypeID('Lyr '), ID);
var desc = new ActionDescriptor();
desc.putReference(charIDToTypeID('null'), ref);
if (add) {
desc.putEnumerated(stringIDToTypeID('selectionModifier'), stringIDToTypeID('selectionModifierType'), stringIDToTypeID('addToSelection'));
desc.putBoolean(charIDToTypeID('MkVs'), false);
executeAction(charIDToTypeID('slct'), desc, DialogModes.NO);
Yes! Jesus, that's beautiful.
I'm picking apart the actions now. From what I can tell, you're defining the styles for the popup window, and then the script checks for all text layers and populates the pulldown with them.
It seems to be ok with detecting text layers in folders.
Any restrictions or scenarios that might cause it to hang up or mangle a text layer (paragraph VS point text; # of text layers present in a file; etc.)?
Thank you for the quick follow up - lots of stuff to work with here!
North America
Asia Pacific
