I have had a folio created at 1024 x 768 available for download for a few weeks, and I'm thinking about putting a ipad3 version of it up (2014 x 1536). What will happen for ipad3 users that have already downloaded the 1024 x 768 version? Will they be offered a 'new' folio to download and therefore end up with 2 versions of this folio - or will their 1024 x 768 version just 'update' to the 2014 x 1536 version?
Also, while I'm on the topic, I've never created a second rendition of a folio before. In the folio producer - do I just propogate the fields (Folio name, publication name, folio number, product id) with the exact same information as the first rendition? this doesn't cause issues haveing two folio's with the exact same info assigned?
Any help appreciated.
Hello!
Your first guess was correct: if a user with an iPad 3 has downloaded your 1024x768 version, and you later publish a 2048x1536 version, they will end up with two versions (the 1024 they downloaded and the 2048 version that's available for download).
And yes, your two renditions have to have the exact same information in every single field. This means not only the folio name and the other things you mentioned, but the meta for each article as well (the sidecar.xml thing is actually useful for that). It doesn't cause any issues; you just have to make sure that if you later make a change to one rendition, you have to do the exact same thing to the other.
I hope this helps ![]()
North America
Asia Pacific
