Adobe Photoshop CS6 Trial - Install.app crashes (Mac OS X 10.7.4)
Aug 19, 2012 11:12 PM
Tags: none (add) #photoshop #mac #install #cs6 #installationI've downloaded the CS6 trial of Adobe Photoshop, both direct and through Adobe Download Manager. Download works fine, but I cannot open the Installer (install.app)
It always crashes, without fail
This is on Mac OS X 10.7.4. I've previously had CS4 installed, but I've removed that completely using Adobe CS Cleaner tool. Also went through and removed *any* Adobe-related files in all my Library folders.
Also attempted to install under a brand new user account, no luck.
Any ideas?
Here's one of my crash logs:
Process: Install [58779] Path: /Volumes/VOLUME/*/Install.app/Contents/MacOS/Install Identifier: com.adobe.PDApp.setup Version: 6.0.335.0 (6.0.335.0) Code Type: X86 (Native) Parent Process: launchd [166] Date/Time: 2012-08-18 21:04:47.645 +1000 OS Version: Mac OS X 10.7.4 (11E53) Report Version: 9 Crashed Thread: 0 Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000 VM Regions Near 0: --> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Volumes/VOLUME/*/Install.app/Contents/MacOS/Install __TEXT 0000000000001000-000000000002c000 [ 172K] r-x/rwx SM=COW /Volumes/VOLUME/*/Install.app/Contents/MacOS/Install Thread 0 Crashed: 0 ??? 0000000000 0 + 0 1 libsystem_kernel.dylib 0x95dc9ef3 mig_get_reply_port + 12 2 libsystem_kernel.dylib 0x95dbdb33 mach_vm_protect + 120 3 ??? 0x00036442 0 + 222274 4 ??? 0x00035b9b 0 + 220059 5 ??? 0x00035cb9 0 + 220345 6 dyld 0x8fe43093 dyld::registerAddCallback(void (*)(mach_header const*, long)) + 109 7 libdyld.dylib 0x90f13078 _dyld_register_func_for_add_image + 74 8 ??? 0x00035a89 0 + 219785 9 ??? 0x0003404f 0 + 213071 Thread 0 crashed with X86 Thread State (32-bit): eax: 0x00000000 ebx: 0xbffffb4c ecx: 0x00000000 edx: 0x00000d07 edi: 0x00000000 esi: 0xac5991bc ebp: 0xbffffa88 esp: 0xbffffa7c ss: 0x00000023 efl: 0x00010282 eip: 0x00000000 cs: 0x0000001b ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f cr2: 0x00000000 Logical CPU: 1 Binary Images: 0x1000 - 0x2bffb +com.adobe.PDApp.setup (6.0.335.0 - 6.0.335.0) /Volumes/VOLUME/*/Install.app/Contents/MacOS/Install 0x8fe40000 - 0x8fe72aa7 dyld (195.6 - ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld 0x90016000 - 0x90024fff com.apple.opengl (1.7.7 - 1.7.7) <2D362F15-5EA6-37B6-9BCB-58F2C599ACDA> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x90025000 - 0x90062ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <1C757924-4E54-3522-A885-99795EA10228> /usr/lib/libcups.2.dylib 0x90b19000 - 0x90b22fff libc++abi.dylib (14.0.0 - compatibility 1.0.0) /usr/lib/libc++abi.dylib 0x90b23000 - 0x90b92fff com.apple.Heimdal (2.2 - 2.0) <2E1B8779-36D4-3C62-A67E-0034D77D7707> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x90c00000 - 0x90c06ffb com.apple.print.framework.Print (7.4 - 247.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x90d6b000 - 0x90d6bfff com.apple.Carbon (153 - 153) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x90e03000 - 0x90e55ff7 libFontRegistry.dylib (??? - ???) <96E9602C-DFD3-3021-8090-60228CC80D26> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x90eac000 - 0x90f11ff7 libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x90f12000 - 0x90f14ff7 libdyld.dylib (195.5.0 - compatibility 1.0.0) <52F7B44C-1B43-3B7B-9C9E-6410D8682935> /usr/lib/system/libdyld.dylib 0x91019000 - 0x91041ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) /usr/lib/libxslt.1.dylib 0x91042000 - 0x9104dffc com.apple.NetAuth (3.1 - 3.1) /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x91085000 - 0x9108affd libGFXShared.dylib (??? - ???) <1CA9B41B-2C61-38F8-ABAC-1D5511478F5C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x9108b000 - 0x910edffb com.apple.datadetectorscore (3.0 - 179.4) <3A418498-C189-37A1-9B86-F0ECB33AD91C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x91232000 - 0x912b9fff com.apple.print.framework.PrintCore (7.1 - 366.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x91386000 - 0x91396fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x9178c000 - 0x9178cff0 com.apple.ApplicationServices (41 - 41) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x9178d000 - 0x918abfec com.apple.vImage (5.1 - 5.1) <7757F253-B281-3612-89D4-F2B04061CBE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x91987000 - 0x91987fff libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <7EFAD88C-AFBC-3D48-BE14-60B8EACC68D7> /usr/lib/system/libdnsinfo.dylib 0x91988000 - 0x91a1eff7 com.apple.LaunchServices (480.33 - 480.33) <5A4BF529-391E-3987-940E-287ACE56078A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x91a1f000 - 0x91a3bffc libPng.dylib (??? - ???) <75F41C08-E187-354C-8115-79387F57FC2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91a3c000 - 0x91a8cff8 libTIFF.dylib (??? - ???) <4DC2025D-15E7-35CA-B7C5-9F73B26C8B53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x91ab1000 - 0x91ab4ffb com.apple.help (1.3.2 - 42) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x91ab5000 - 0x91af5ff7 libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib 0x91af6000 - 0x91b25ff7 libsystem_info.dylib (??? - ???) <37640811-445B-3BB7-9934-A7C99848250D> /usr/lib/system/libsystem_info.dylib 0x91b26000 - 0x91b29ffd libCoreVMClient.dylib (??? - ???) <361CCFAF-8565-383F-915F-0B059C793E42> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x91b2a000 - 0x91b73ff7 libGLU.dylib (??? - ???) <5EE0B644-FAD6-3E3C-A380-9B0CDA0B6432> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x91b74000 - 0x91bb0ffa libGLImage.dylib (??? - ???) <504E7865-571E-38B4-A84A-D7B513AC84F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x91bb1000 - 0x91bb9ff3 libunwind.dylib (30.0.0 - compatibility 1.0.0) /usr/lib/system/libunwind.dylib 0x91bba000 - 0x91bbafff com.apple.Cocoa (6.6 - ???) <5FAFE73E-6AF5-3D09-9191-0BDC8C6875CB> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x91bfd000 - 0x91c05ff3 liblaunch.dylib (392.38.0 - compatibility 1.0.0) /usr/lib/system/liblaunch.dylib 0x91d5e000 - 0x91d62fff libGIF.dylib (??? - ???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x91d63000 - 0x91dd9fff com.apple.Metadata (10.7.0 - 627.32) <650EE880-1488-3DC6-963B-F3D6E043FFDC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x91dda000 - 0x91eeafe7 libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <34E1E3CC-7B6A-3B37-8D07-1258D11E16CB> /usr/lib/libsqlite3.dylib 0x91f1d000 - 0x91f85ff7 libc++.1.dylib (28.1.0 - compatibility 1.0.0) /usr/lib/libc++.1.dylib 0x920b5000 - 0x920d7ff8 com.apple.PerformanceAnalysis (1.11 - 11) <453463FF-7C42-3526-8C96-A9971EE07154> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x920d8000 - 0x9239bfff com.apple.security (7.0 - 55148.1) <77754898-4FCD-3CA3-9339-F1058C852806> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x923c8000 - 0x923caffb libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x923cb000 - 0x926cdfff com.apple.CoreServices.CarbonCore (960.24 - 960.24) <9692D838-85A5-32C1-B7FB-7C141FFC2557> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x927cf000 - 0x92843fff com.apple.CoreSymbolication (2.2 - 73.2) /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x92848000 - 0x9284fffd com.apple.NetFS (4.0 - 4.0) /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x92850000 - 0x92858ff5 libcopyfile.dylib (85.1.0 - compatibility 1.0.0) /usr/lib/system/libcopyfile.dylib 0x92859000 - 0x92968fff com.apple.DesktopServices (1.6.3 - 1.6.3) <18CAAA9E-7065-3FF7-ACFE-CDB60E5426A2> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x92a99000 - 0x9352eff6 com.apple.AppKit (6.7.3 - 1138.47) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x93c62000 - 0x93c6dffe libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) /usr/lib/libbz2.1.0.dylib 0x93cc5000 - 0x93d40ffb com.apple.ApplicationServices.ATS (317.11.0 - ???) <42238C8B-C93F-3369-A500-EC0F10EB2C80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x93e8e000 - 0x93ebcff7 com.apple.DictionaryServices (1.2.1 - 158.2) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x93ebd000 - 0x947e759b com.apple.CoreGraphics (1.600.0 - ???) <62026E0C-E30F-3FF0-B0F6-6A2D270B20BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x947e8000 - 0x947e8fff com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x947f7000 - 0x948c2fff libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <52421B00-79C8-3727-94DE-62F6820B9C31> /usr/lib/system/libsystem_c.dylib 0x948c3000 - 0x948cefff libkxld.dylib (??? - ???) /usr/lib/system/libkxld.dylib 0x948d1000 - 0x94994fff com.apple.CoreServices.OSServices (478.46 - 478.46) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x94a04000 - 0x94a08ffa libcache.dylib (47.0.0 - compatibility 1.0.0) <56256537-6538-3522-BCB6-2C79DA6AC8CD> /usr/lib/system/libcache.dylib 0x94ac6000 - 0x94b1ffff com.apple.HIServices (1.21 - ???) <5F4D3797-32E2-3709-85F4-4B56515A17D7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x94b24000 - 0x94b47fff com.apple.CoreVideo (1.7 - 70.3) <4234C11C-E8E9-309A-9465-27D6D7458895> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x94b98000 - 0x94c88ff1 libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib 0x94c89000 - 0x94cd1ff7 com.apple.SystemConfiguration (1.11.3 - 1.11) <68B92FEA-F754-3E7E-B5E6-D512E26144E7> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x94cd2000 - 0x94e24fff com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x94e25000 - 0x94e68ffd libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <6B35F203-5D72-335A-A4BC-CC89FEC0E14F> /usr/lib/system/libcommonCrypto.dylib 0x94e69000 - 0x94f29ffb com.apple.ColorSync (4.7.4 - 4.7.4) <0A68AF35-15DF-3A0A-9B17-70CE2A106A6C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x94f2a000 - 0x95406ff6 libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x95407000 - 0x954ffff7 libFontParser.dylib (??? - ???) <1A0DA421-62B2-3AA7-9F62-0E01C1887D09> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x95500000 - 0x95501ff7 libquarantine.dylib (36.6.0 - compatibility 1.0.0) <600909D9-BD75-386E-8D3E-7CBD29079DF3> /usr/lib/system/libquarantine.dylib 0x95502000 - 0x9558ffe7 libvMisc.dylib (325.4.0 - compatibility 1.0.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x9566b000 - 0x9566fffd IOSurface (??? - ???) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x956a3000 - 0x956d9ff7 com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x956da000 - 0x9573efff com.apple.framework.IOKit (2.0 - ???) <88D60E59-430D-35B8-B1E9-F5138301AEF9> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x9574a000 - 0x95757fff libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x95768000 - 0x95776fff libdispatch.dylib (187.9.0 - compatibility 1.0.0) <2F918480-12C8-3F22-9B1A-9B2D76F6F4F5> /usr/lib/system/libdispatch.dylib 0x95abe000 - 0x95b20ff3 libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib 0x95b4f000 - 0x95c32ff7 libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) /usr/lib/libcrypto.0.9.8.dylib 0x95c86000 - 0x95db2ff9 com.apple.CFNetwork (520.4.3 - 520.4.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x95db3000 - 0x95dd1ff7 libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <3705DE40-E00F-3E37-ADB0-D4AE5F9950F5> /usr/lib/system/libsystem_kernel.dylib 0x95dd2000 - 0x95de0ff7 libxar-nossl.dylib (??? - ???) <5BF4DA8E-C319-354A-967E-A0C725DC8BA3> /usr/lib/libxar-nossl.dylib 0x95de1000 - 0x96256ff7 FaceCoreLight (1.4.7 - compatibility 1.0.0) <3E2BF587-5168-3FC5-9D8D-183A9C7C1DED> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight 0x96257000 - 0x9625eff9 libsystem_dnssd.dylib (??? - ???) /usr/lib/system/libsystem_dnssd.dylib 0x9625f000 - 0x96260ffd libCVMSPluginSupport.dylib (??? - ???) <22B85645-AA98-372B-BB55-55DCCF0EC716> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x96261000 - 0x96459ff7 com.apple.CoreData (104.1 - 358.14) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x9645a000 - 0x964b8fff com.apple.coreui (1.2.2 - 165.10) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x96767000 - 0x96a71ff3 com.apple.Foundation (6.7.2 - 833.25) <4C52ED74-A1FD-3087-A2E1-035AB3CF9610> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x96a72000 - 0x96a78ffd com.apple.CommerceCore (1.0 - 17) /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore 0x96a79000 - 0x96a87fff libz.1.dylib (1.2.5 - compatibility 1.0.0) /usr/lib/libz.1.dylib 0x96ad5000 - 0x96c89ff3 libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib 0x96fa5000 - 0x96fa5fff com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x97015000 - 0x9703aff9 libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x9703b000 - 0x97050ff7 com.apple.ImageCapture (7.0.1 - 7.0.1) <1C8933A9-C7C6-36E9-9D8B-0EF08ACA3315> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x97051000 - 0x97054ffc libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib 0x97055000 - 0x97056fff libDiagnosticMessagesClient.dylib (??? - ???) /usr/lib/libDiagnosticMessagesClient.dylib 0x97057000 - 0x9705eff7 libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib 0x9705f000 - 0x9706affb com.apple.speech.recognition.framework (4.0.21 - 4.0.21) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x9706b000 - 0x97070ff7 libmacho.dylib (800.0.0 - compatibility 1.0.0) <943213F3-CC9B-328E-8A6F-16D85C4274C7> /usr/lib/system/libmacho.dylib 0x97071000 - 0x970a8fef com.apple.DebugSymbols (2.1 - 87) /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x970a9000 - 0x970d2ffe com.apple.opencl (1.50.69 - 1.50.69) <2601993F-F3B3-3737-91AE-4A5795C52CD5> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x97202000 - 0x97313ff7 libJP2.dylib (??? - ???) <845C74F4-1074-3983-945F-EB669538CAA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x9732a000 - 0x9732dff7 libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib 0x9737b000 - 0x97451aab libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <2E272DCA-38A0-3530-BBF4-47AE678D20D4> /usr/lib/libobjc.A.dylib 0x9749f000 - 0x974a3fff com.apple.CommonPanels (1.2.5 - 94) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x97621000 - 0x97636fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x97cc9000 - 0x97cc9ffe libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib 0x97ccd000 - 0x97cceff7 libsystem_sandbox.dylib (??? - ???) /usr/lib/system/libsystem_sandbox.dylib 0x97d14000 - 0x97d28fff com.apple.CFOpenDirectory (10.7 - 146) <58050170-D74E-3670-945D-D8501F67835F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x97d42000 - 0x97d9dff3 com.apple.Symbolication (1.3 - 91) <4D12D2EC-5010-3958-A205-9A67E972C76A> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x97daa000 - 0x97e4efff com.apple.QD (3.40 - ???) <3881BEC6-0908-3073-BA44-346356E1CDF9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x97e4f000 - 0x97e50fff liblangid.dylib (??? - ???) /usr/lib/liblangid.dylib 0x9892e000 - 0x9898fffb com.apple.audio.CoreAudio (4.0.2 - 4.0.2) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x98990000 - 0x98a78fff libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <1841196F-68B5-309F-8ED1-6714B1DFEC83> /usr/lib/libxml2.2.dylib 0x98a91000 - 0x98a92fff libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) /usr/lib/system/libsystem_blocks.dylib 0x98a93000 - 0x98dd9ff3 com.apple.HIToolbox (1.9 - ???) <409E6397-0DCB-3431-9CCC-368317C62545> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x99fbe000 - 0x9a048ffb com.apple.SearchKit (1.4.0 - 1.4.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x9a049000 - 0x9a051fff com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x9a71d000 - 0x9ab1fff6 libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x9ab20000 - 0x9abadff7 com.apple.CoreText (220.20.0 - ???) <0C3EDD4F-6112-353A-8A3A-8D630182C22A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x9abae000 - 0x9ac0bffb com.apple.htmlrendering (76 - 1.1.4) <409EF0CB-2997-369A-9326-BE12436B9EE1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x9ac14000 - 0x9ac14ff2 com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x9ac15000 - 0x9ac1eff3 com.apple.CommonAuth (2.2 - 2.0) /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x9ac1f000 - 0x9acb6ff3 com.apple.securityfoundation (5.0 - 55116) /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x9acb7000 - 0x9ace2fff com.apple.GSS (2.2 - 2.0) <2C468B23-FA87-30B5-B9A6-8C5D1373AA30> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x9ace3000 - 0x9acf3ff7 libCRFSuite.dylib (??? - ???) <94E040D2-2769-359A-A21B-DB85FCB73BDC> /usr/lib/libCRFSuite.dylib 0x9acf4000 - 0x9acf5ff4 libremovefile.dylib (21.1.0 - compatibility 1.0.0) <6DE3FDC7-0BE0-3791-B6F5-C15422A8AFB8> /usr/lib/system/libremovefile.dylib 0x9acf6000 - 0x9ad24fe7 libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <30189C33-6ADD-3142-83F3-6114B1FC152E> /usr/lib/libSystem.B.dylib 0x9ad25000 - 0x9ad25fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x9ad51000 - 0x9ad6dff5 com.apple.GenerationalStorage (1.0 - 126.1) /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x9ad6e000 - 0x9ad7ffff libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib 0x9ae95000 - 0x9aeaffff com.apple.Kerberos (1.0 - 1) /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x9aeb0000 - 0x9aeb1fff com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x9aeb4000 - 0x9b127ffb com.apple.CoreImage (7.98 - 1.0.1) /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x9b128000 - 0x9b148ff7 com.apple.RemoteViewServices (1.4 - 44.1) <1F831750-1E77-3013-B1A6-0DF528623790> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x9b149000 - 0x9b1e5fef com.apple.ink.framework (1.4 - 110) <1A3E2916-60C1-3AC1-86BF-202F6567B228> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x9b1e6000 - 0x9b1f0ff2 com.apple.audio.SoundManager (3.9.4.1 - 3.9.4.1) <2A089CE8-9760-3F0F-B77D-29A78940EA17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x9b1f1000 - 0x9b213ffe com.apple.framework.familycontrols (3.0 - 300) <5BCCDDC2-AFAC-3290-AEEF-23B2664CA11F> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls 0x9b256000 - 0x9b3b8ffb com.apple.QuartzCore (1.7 - 270.4) <6BC84C60-1003-3008-ABE4-779EF7B4F524> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x9b4f7000 - 0x9b4fbff7 com.apple.OpenDirectory (10.7 - 146) <4986A382-8FEF-3392-8CE9-CF6A5EE4E365> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x9b7f6000 - 0x9b9cdfe7 com.apple.CoreFoundation (6.7.2 - 635.21) <4D1D2BAF-1332-32DF-A81B-7E79D4F0A6CB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x9b9d6000 - 0x9b9f3fff libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <2870320A-28DA-3B44-9D82-D56E0036F6BB> /usr/lib/libresolv.9.dylib 0x9b9f4000 - 0x9ba11ff3 com.apple.openscripting (1.3.3 - ???) <33713C0B-B7D5-37AA-87DB-2727FDCC8007> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x9ba1f000 - 0x9baefffb com.apple.ImageIO.framework (3.1.2 - 3.1.2) <94798A2B-4C7A-30EA-9920-283451BDB9FA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x9baf0000 - 0x9baf1ff0 libunc.dylib (24.0.0 - compatibility 1.0.0) <2F4B35B2-706C-3383-AA86-DABA409FAE45> /usr/lib/system/libunc.dylib 0x9baf2000 - 0x9baf4ff9 com.apple.securityhi (4.0 - 1) <39157216-5E43-392A-AE3F-716726D8C8BF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x9baf5000 - 0x9bb0bffe libxpc.dylib (77.19.0 - compatibility 1.0.0) <0585AA94-F4FD-32C1-B586-22E7184B781A> /usr/lib/system/libxpc.dylib 0x9bb13000 - 0x9bb53ff7 com.apple.NavigationServices (3.7 - 193) <16A8BCC8-7343-3A90-88B3-AAA334DF615F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x9c1ef000 - 0x9c202ff8 com.apple.MultitouchSupport.framework (231.4 - 231.4) <083F7787-4C3B-31DA-B5BB-1993D9A9723D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x9c203000 - 0x9c203fff com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x9c204000 - 0x9c208ff3 libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib 0x9c209000 - 0x9c20cff7 libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib 0x9c267000 - 0x9c2b8ff9 com.apple.ScalableUserInterface (1.0 - 1) <3C39DF4D-5CAE-373A-BE08-8CD16E514337> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 2 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 127527 thread_create: 1 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=127.2M resident=91.8M(72%) swapped_out_or_unallocated=35.4M(28%) Writable regions: Total=8420K written=60K(1%) resident=116K(1%) swapped_out=0K(0%) unallocated=8304K(99%) REGION TYPE VIRTUAL =========== ======= Stack 64.0M VM_ALLOCATE 44K __CI_BITMAP 80K __DATA 6524K __DATA/__OBJC 12K __IMAGE 528K __IMPORT 8K __LINKEDIT 40.0M __OBJC 1724K __OBJC/__DATA 164K __PAGEZERO 4K __TEXT 87.3M __UNICODE 544K mapped file 116.4M shared memory 12K shared pmap 2368K =========== ======= TOTAL 319.3M
