Run Photoshop in 32-bit mode (64-bit Mac OS only)
Aug 21, 2012 8:37 PM
    Aug 21, 2012 8:37 PM   in reply to Community Help
    don't knwo how to select Open In 32-bit Mode. would you please help us?
    Aug 21, 2012 8:50 PM   in reply to keeshapan
    In 64-bit versions of Mac OS 10.5 and later, some older, optional plug-ins are available only if Photoshop is running in 32-bit mode:
    1. In the Finder, choose Go > Applications.
    2. Expand the Photoshop folder. Then right-click the Photoshop application icon, and choose Get Info.
    3. In the General section of the Info window, select Open In 32-bit Mode.
    4. Close the Info window, and restart Photoshop.
    Aug 22, 2012 1:34 AM   in reply to Bo LeBeau
    thank you very much for yout help .but when i follow the step3 ,there is no In 32-bit Mode for me to select .would you help to check this agian ?thanks you very much.
    Aug 22, 2012 1:49 AM   in reply to keeshapan
    What version of photoshop?
    What version of OS X?
    Aug 22, 2012 1:58 AM   in reply to R_Kelly
    version of photoshop:both CS5 and CS6
    OS X:10.6.8 64-bit
    Aug 22, 2012 2:09 AM   in reply to keeshapan
    Could you please post a screenshot?
    Aug 22, 2012 2:34 AM   in reply to c.pfaffenbichler
    on my mac,no such options.how to make it display?
    Aug 22, 2012 2:46 AM   in reply to keeshapan
    Aug 22, 2012 3:22 AM   in reply to keeshapan
    In CS6, there is indeed no such option, because there is not a 32-bit version of CS6 for the Mac.  CS6 is only available in 64 bit for the Mac.
    The only version that will give you that option on the Mac is CS5.
    There is no such option in CS4, because that version was only 32-bit on the Mac.
    Aug 22, 2012 4:30 AM   in reply to station_two
    actually when i use CS5, it still no such option .whether it is the Mac 10.6 64Bit or 32bit.
    i just want plug-in a scanner,what should i do ?Help...
    Aug 22, 2012 4:33 AM   in reply to c.pfaffenbichler
    the screenshot is same as yours except the option.
    maybe it's my CS's prooblem ,like station_two  said.
    Aug 22, 2012 3:41 PM   in reply to keeshapan
    That option is there in Photoshop CS5.
    Make sure you selected the APPLICATION and not just the folder that the application resides in.
    Aug 22, 2012 4:20 PM   in reply to Chris Cox
    how silly of me ,i found this option ,
    as you said ,i fond this option by select the folder ,not the application ,
    thank you vvvvvvvvery much!
    Do you know why i still can't plug-in a scanner?
    on 64-bit Mac OS ,32-bit mode Photoshop.and i have download the plug-in file .
    Aug 22, 2012 6:53 PM   in reply to Chris Cox
    thank you very much for the help ,i think i can solve this problem in another way .thank you .
    Sep 26, 2012 11:55 PM   in reply to keeshapan
    Go to Applications -  Choose Adobe Photoshop CS5 - Choose Adobe Photoshop CS5 - Then Click "More Info" button  below the application Icon - Check the Open in 32-bit Mode Option- Close the window - Open Photoshop
    Sep 27, 2012 1:17 AM   in reply to Rajesh Malik
    thank you for your help.^^
    Dec 4, 2012 10:16 AM   in reply to Community Help
    I have the same problem trying to run the mac on 64 bit but don't see the option
    Dec 4, 2012 10:54 AM   in reply to pCaro@inn
    Only Photoshop CS5 included the option to run in either a 32-bit or 64-bit mode. Are you running Photoshop CS6?
    regards,
    steve
    Dec 4, 2012 10:56 AM   in reply to SG...
    Yes, however I cannot change it to run in 64 mode, how do I do it?
    Dec 4, 2012 11:07 AM   in reply to pCaro@inn
    OK, I'm not following what problem you're having. You have Ps CS6 installed, what are you trying to change for running in 64-bit mode?
    thx-steve
    Dec 4, 2012 11:38 AM   in reply to SG...
    Ok, so I need to run picture package, but I  read I have to change the mode of my mac to run this plugin.
    Apparently I can run this application to print 2 12X16 frames side by side on  a 44"X35" canvas roll.
    Dec 4, 2012 11:55 AM   in reply to pCaro@inn
    Hi, Picture Package is not available or compatible with Ps CS6. Take a look at File> Automate> Contact Sheet II... which was reintroduced as a shipping command in Ps CS6.
    Dec 4, 2012 12:04 PM   in reply to SG...
    Yes, just did it says; this functionality may not be available in this trial version of photoshop. Completely lost at this point.
    Sent from my BlackBerry® wireless device
    Apr 2, 2013 7:53 AM   in reply to pCaro@inn
    I can't see the 32 mode in the info part of cs5Screen Shot 2013-04-02 at 9.51.13 AM.png
  • JJMack
    Jan 9, 2006
    Apr 2, 2013 8:19 AM   in reply to pCaro@inn
    With Mac CS6 you can get the Picture Package function using Scripts in my Photo Collage Toolkit. For complex layouts you will need to create template that match the layouts in cs5 preset/layouts folder.  If you just need to tile same size images onto large paper like roll paper the PasteImageRoll script can do that without the need of a template.
    http://www.mouseprints.net/old/dpr/PasteImageRoll.html
    The scripts work on both PC and Mac OS Photoshop download http://www.mouseprints.net/old/dpr/PhotoCollageToolkit.zip
    Sep 10, 2013 12:32 PM   in reply to keeshapan
    Same here -- no 'Open in 32-bit mode' option for me to select, and I am doing the Command-I on the CS5 app icon, not the folder. Screen shot attached. Suggestions welcome! Lighting effects is a great tool.
    Sep 10, 2013 3:57 PM   in reply to SG...
    I installed the picture package into PSCS6 without any trouble but I have Windows OS.
