Extension Builder and CS6 - read version at runtime
Aug 22, 2012 1:12 PM
I want to check the version of my CS extension at main .mxml init time.
How does one find this version info from the manifest.xml?
pjb
    Sep 10, 2012 6:02 AM   in reply to PeteBaumgartner
    Try "Gathering environment information" topic.
    I hope it helps !
    Sep 10, 2012 9:21 AM   in reply to PeteBaumgartner
    AFAIK there is no API exposed by CSXS to get the bundle version. You can read the XML of the manifest and pull out the version though:
    private function getExtensionVersion(manifestFile:File):String
         var fileStream:FileStream = new FileStream();
         fileStream.open(manifestFile, FileMode.READ);
         var manifestXml:XML = XML(fileStream.readUTFBytes(fileStream.bytesAvailable));
         fileStream.close();
         return manifestXml.@ExtensionBundleVersion;
    var version:String = getExtensionVersion(basePath.resolvePath('CSXS/manifest.xml'));
    Note that basePath is a property on CSExtension.
    Hope that helps,
    --Louis
    Apr 19, 2013 5:52 AM   in reply to lomorgan
    I seem to be having probelm getting the basePath I've looked everywhere I could to fine it.
    Could give me a example of how to get the basePath? or what import needs to be used?
    Apr 19, 2013 6:17 AM   in reply to kc2scy
    In your MXML file, CSExtension should be the root class. Then you can use "this.basePath":
    <csxs:CSExtension xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:csxs="com.adobe.csxs.core.*" applicationComplete="appComplete()">
    <fx:Script>
                        <![CDATA[
          public function appComplete():void
            trace(this.basePath);
              </fx:Script>
    </csxs:CSExtension>
    Apr 19, 2013 6:48 AM   in reply to lesavage
    Thank You!
