After taking the time to set Encore chapters in Premiere CS6 (and yes, I made sure they were Encore chapters and not regular ones), when I imported a timeline into Encore CS6 there are no chapters.
Are those Encore chapters only for DVD? I don't know if it makes any difference, but I exported using the Matrox Blu-ray module in Premiere to be able to use the Matrox Mini MXO2 Max that I paid good money for to be able to encode faster.
I don't know which versions of Premiere, Encore, and Matrox drivers you're using, but from the Matrox "Release Notes" for 5.5 I found the following -
When you export an Adobe Premiere Pro sequence that has chapter markers
to a Matrox MAX H.264 file, the chapter markers are not exported and
therefore won’t be available when you import your exported file to Adobe
Encore. (Ref# 51780)
So, it looks like you will just have to plan on adding chapter markers in Encore to use the MAX workflow
Jeff Pulera
Safe Harbor Computers
Actually I click on the timecode in PR, copy, then click on the timecode in Encore and paste. Still annoying when you have several chapters. But as far as setting the GOP limits in the right places, I'm not sure Premiere is even doing that. In another project I set Encore chapters in Premiere, then encoded from Premiere using its own MPEG-2 DVD encoder, and Encore recognizes the chapters, but they are not frame accurate, which is obvious because I set a lot of them right in the middle of a fade in-fade out where it should be completely black, and Encore shows the chapters a few frames before or after. And this has nothing to do with the Matrox encoder, so I don't know what's the deal.
When using a GOP structure file, Encore will only be able to place Chapter Markers on I-Frames, and not on the "difference Frames."
Sorry about that.
GOP = Group of Pictures. In many formats, there are only I-Frames (with all info) about every 8 - 15 Frames. All between those are "difference Frames," and do not contain all of the data to form the image of the Frames. This article goes into more detail: http://forums.adobe.com/thread/544204?tstart=90
Stan Jones wrote:
But his point at post 6 is that he sets the markers in PR and exports from PR as Mpeg2-DVD, which should result in accurate placement.
Sebasvideo, can you confirm that the marker timecode in PR is the same as the time in EN?
Right, I know what a GOP is, I wasn't sure what Bill was referring to as "GOP structure file". But I know that the main point of setting DVD chapters in most NLEs is to ensure that there will be an I frame at that exact frame so the chapter break can be accurate.
That said, I opened the project in Premiere and I see that all the Encore chapters are moved from where they were supposed to be, which I have no idea how it happened. Maybe I made a mistake and did an unwanted trim operation somewhere.
If ADL is used, or a DV-AVI Export from PrPro w/ En Chapter Markers, the Markers should be on the Frame chosen, and in those cases, GOP would not play a role.
If I understand your point. Same is now true for mpeg2-dvd out put from PR (or ame).
The way I did not interpret it, but perhaps what you meant, is that a PR project with markers, having done the export, can't have a gop issue for the markers in EN, since they will be on GOPs.
Also looking for a better work around for this!
The export SHOULD be made be sensible enough to drop/force in a keyframe whether ever you put a chapter marker regradless of underlying GOP in source
Without this feature the workflow sucks using 3rd party chapter inserters on MAC, may as well use FCP X, which does support it.
North America
Asia Pacific
